[Geoserver-devel] 1.7.5 release and release guide notes
while I was doing the 1.7.5 release I made a review of the release
guide. I found a few topics worth discussing:
Here are the items:
- a paragraph talking about mails to gt2 devel and gs devel was
   missing, I added it
- I also added a paragraph about the prerequisites (commit and
   admin rights one has to have in order to make a release)
- there is no mention of the parallel gt2 release. From experience
   the suggestion would be to tag gt2, run the cite, make the
   necessary fixes, and once the cite work, release gt2
- the updated README step is first, but it requires a link to
   the JIRA release notes. It is actually possible to make the
   link beforehand, but that was not obvious to me at first,
   so I added a comment
- some sed commands missed the -i flag
- the guide suggest to make the cite tests and the hand tests
   after uploading the arftifacs to sf. What if the cite
   do fail? Imho they should be run from the IDE
   (assuming a totally clean checkout)
   or from the release artifacts before the release.
   (I haven't included this change in the attached patch)
- the sf file release system now allows a simple scp
   upload in the form:
   scp *.zip user@anonymised.com:uploads
   which should be simple enough to follow for both windows
   and linux users. Shall we replace the dav/sftp suggestions?
- the steps to make a release on sf changed again. Now one
   has to go in Project Admin/Feature Settings, choose
   the "manage" button in the "File Release System" row,
   and then continue as usual. This is included in the
   diff attached
- the last steps about announcements are a bit tricky.
   I guess we do want to announce first on the blog,
   which requires review, so those steps are to be
   performed in the days after the release no?
Most of the changes above (minus the ones explicitly
replaces the same named file in the dev guide).
The funny thing is that at the same time I edited a bit
the GeoTools release guide.. oh, boy, what a pain, working
with Sphinx is so much better :slight_smile:
And oh, here are the CITE tests results:
wfs 1.0 full pass
wfs 1.1 full pass (besides usual postgres 8.3 failure on like on dates)
wms 1.1 full pass
wcs 1.0 full pass
wcs 1.1 full pass
I did not manage to run the xlink tests thought, the h2
configuration does not work and it seems on 2.5.x the
spatialdb in a box functions were not ported over.
Oh well, I guess it's not much of an issue, xlink works
only in H2 anyways (or at least it was tested only there).
Andrea Aime
OpenGeo - http://opengeo.org
(attachments)
resguide.patch (3.31 KB)
Andrea Aime ha scritto:
And oh, missed one important point: I cannot make the OSX
release, someone Mac-enabled will have to do it and upload
the artifact to Sourceforge.
Andrea Aime
Sure I can do that. And I applied your changes to the release guide (with some tweaks). Thanks Andrea.
Justin Deoliveira
Justin Deoliveira ha scritto:
Looked at the release guide this morning, it looks great.
I noticed a couple of things thought:
- the image I provided was not used, sf1.png still depicts the old
   SF UI
- the part dealing with SF uploads is outdated and points to a sf
   page that is no more there.
For the latter I did not actually provide a patch, but there was
some comments in my mail with a question:
   upload in the form:
Mind if I change that part of the release guide to follow to
above suggestion?
Andrea Aime
  SF UI
  upload in the form:
above suggestion?
Oops, missed that. Sure thing, make the changes as you see fit.
-Justin
Justin Deoliveira
