[Geoserver-devel] 1.7.x and geoapi
I notice the current version of geoapi gs 1.7.x is working against is 2.2-SNAPSHOT. But doing a build on a fresh checkout and recent version of geoapi 2.2.x it does not build. Changing to 2.2-M2 works ok. Is there any reason we are not pegging 1.7.x against geoapi 2.2-M2?
-Justin
Justin Deoliveira
OpenGeo - http://opengeo.org
GeoTools 2.5.x is supposed to be pegged against 2.2-M2.
When you say go we were going to release 2.2-M2 as the GeoAPI 2.2.0
release simply to close off this development stream.
So to answer your question - there is no reas to use 2.2-SNAPSHOT.
Jody
On Sat, Mar 14, 2009 at 8:37 AM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
-Justin
Justin Deoliveira
Apps built with the Adobe(R) Flex(R) framework and Flex Builder(TM) are
powering Web 2.0 with engaging, cross-platform capabilities. Quickly and
easily build your RIAs with Flex Builder, the Eclipse(TM)based development
software that enables intelligent coding and step-through debugging.
Download the free 60 day trial. http://p.sf.net/sfu/www-adobe-com
Geoserver-devel mailing list
