[Geoserver-devel] 1.7.x branch created (please read)
I have created the 1.7.x branch in subversion. For those of you who are developing on trunk and require a stable target to work against, you should work against 1.7.x. So this means you need to re-checkout (or svn switch) your current tree from https://svn.codehaus.org/geoserver/branches/1.7.x
For those who like to live on the edge you can continue working happily on the ever exciting trunk. The only thing to keep in mind is that pom versions have changed to 1.8.0-SNAPSHOT. So you should probably do the following to avoid any stale references to the 1.7.x branch.
1. svn update
2. do a full build
3. run mvn eclipse:eclipse
Enjoy.
-Justin
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
