Hi David,
I guess I misunderstood our last conversation, I did not think any commits were going to occur on 1.7.x... and just for 1.7.1. Regardless, is there a jira issue describing this issue? I don't see one scheduled against 1.7.0. Or a relevant mailing list thread?
Sorry to be a nag, I just want to know why we are breaking the freeze and don't remember any conversation about actual bug.
-Justin
dwinslow@anonymised.com wrote:
Revision
10417 <http://fisheye.codehaus.org/changelog/geoserver/?cs=10417>
Author
dwinslow
Date
2008-10-16 20:13:18 -0500 (Thu, 16 Oct 2008)
Log Message
The REAL fix for the request logging filter.
Modified Paths
* branches/1.7.x/geoserver/web/src/main/java/org/geoserver/filters/BufferedRequestStream.java
<#branches17xgeoserverwebsrcmainjavaorggeoserverfiltersBufferedRequestStreamjava>
Diff
Modified:
(10416 => 10417)
--- branches/1.7.x/geoserver/web/src/main/java/org/geoserver/filters/BufferedRequestStream.java 2008-10-16 23:59:44 UTC (rev 10416)
+++ branches/1.7.x/geoserver/web/src/main/java/org/geoserver/filters/BufferedRequestStream.java 2008-10-17 01:13:18 UTC (rev 10417)
@@ -1,23 +1,22 @@
package org.geoserver.filters;
import javax.servlet.ServletInputStream;
+import java.io.ByteArrayInputStream;
import java.io.InputStream;
import java.io.IOException;
-import java.io.StringReader;
-import java.io.Reader;
* Wrap a String up as a ServletInputStream so we can read it multiple times.
* @author David Winslow <dwinslow@anonymised.com>
public class BufferedRequestStream extends ServletInputStream{
- Reader myReader;
+ InputStream myStream;
public BufferedRequestStream(String buff) throws IOException {
- myReader = new StringReader(buff);
- myReader.mark(16);
- myReader.read();
- myReader.reset();
+ myStream = new ByteArrayInputStream(buff.getBytes());
+ myStream.mark(16);
+ myStream.read();
+ myStream.reset();
public int readLine(byte b, int off, int len) throws IOException{
@@ -26,7 +25,7 @@
int end = off + len;
while (index < end && - (read = myReader.read()) != -1){
+ (read = myStream.read()) != -1){
b[index] = (byte)read; index++;
if (((char)read)== '\n'){
@@ -38,6 +37,10 @@
public int read() throws IOException{
- return myReader.read();
+ return myStream.read();
+ public int available() throws IOException {
+ return myStream.available();
To unsubscribe from this list please visit:
http://xircles.codehaus.org/manage_email
Justin Deoliveira
OpenGeo - http://opengeo.org
Here's the bug:
http://jira.codehaus.org/browse/GEOS-2281
What I did was exactly what I said I would do; roll back the .available() fix (which had been committed on 1.7.x already) and modify the request logging filter to avoid triggering the problem. This bug is pretty minor (it only shows up when POST body logging is enabled, so there's an easy workaround) so waiting for 1.7.1 is fine.
-David
Justin Deoliveira wrote:
Hi David,
-Justin
Revision
Author
dwinslow
Date
Log Message
Modified Paths
Diff
Modified:
(10416 => 10417)
@@ -1,23 +1,22 @@
- Reader myReader;
- myReader.read();
- myReader.reset();
+ myStream.read();
+ myStream.reset();
@@ -26,7 +25,7 @@
@@ -38,6 +37,10 @@
David Winslow wrote:
Here's the bug:
Ok, its not scheduled against a version...
The last message I got from you stated that you would "revert on 1.7.x", which i assumed to mean no commits would be taking place. When in reality you just replaced a commit to one core class with a commit to another. I apologize for missing this in your original mail.
roll back the
In all honesty I would prefer kicking the bug back. Our "informal" freeze breaking policy has been only to commit changes for serious regressions and bugs, like the recent issue with leaking postgis connections.
Perhaps this bug is serious enough? Not sure. Andrea, what do you think?
-David
Hi David,
-Justin
Revision
Author
dwinslow
Date
Log Message
Modified Paths
Diff
Modified:
(10416 => 10417)
@@ -1,23 +1,22 @@
- Reader myReader;
- myReader.read();
- myReader.reset();
+ myStream.read();
+ myStream.reset();
@@ -26,7 +25,7 @@
@@ -38,6 +37,10 @@
Justin Deoliveira
Here's the bug:
roll back the
No need to touch 1.7.x right now, the bug occurs only on trunk afaik
Andrea Aime
