Hi guys, may be some of you could bring some light to this problem that's killing me.
I got a 3-band, 16-bit unsigned raster, whose sample range is 0..255 and the nodata value is 256. I need to get geoserver interpreting it as an RGB image and it does, only that since the sample range is so stretch it's seen black. That is using a SLD with red, green and blue channel selection for bands 1, 2 and 3 respectively.
But I can't find a way to create a better raster symbolizer where I can use the three bands as r,g,b.
Any idea?
Gabriel
Gabriel Roldan
OpenGeo - http://opengeo.org
