[Geoserver-devel] 2.0.1 benchmarking results
for the Lugano FOSS4G-IT 2010 conference I run the benchmarks
against GS 2.0.1 and updated the results on the benchmarking
wiki page:
http://geoserver.org/display/GEOS/GeoServer+benchmarks
As you can see 2.0.1 got substantially faster in some tests
thanks to the fix in the PNG compression level (GS 2.0.0 was
released by mistake with an overly high PNG compression
level that resulted in a lot of work for very little
output size advantages).
There is also a very small improvement in the raster results
thanks to Gabriel observation about the CommonFactoryFinder
synchronization bottlenecks... though you already know we're
shooting much higher for 2.1.x
Andrea Aime
OpenGeo - http://opengeo.org
