[Geoserver-devel] 2.0-alpha2 release progress
A quick update for where things are at.
* cite tests are good to go for wfs. Soon we are going to need a matrix for wfs cite tests :). But basically here are the tested configurations:
wfs 1.0 postgisng with normal encoder --> check
wfs 1.0 postgisng with gtxml encoder --> check
wfs 1.0 h2 with gtxml encoder --> check
wfs 1.1 h2 --> check
wfs 1.1 postgisng --> fail **
** the remaining failures (only a handful) are due to how the jdbc-ng drivers figure out what the feature id's are for inserted features. Basically it tries to determine what the next fid will be before the insert occurs which is an incorrect way of doing this. Especially with postgis where we a) have the ability to figure out the sequence attached to a column and b) have the currval and lastval functions at our disposal
I actually haven't run wms or wcs cite tests yet, but usually they are pretty boring (famous last words).
* release artifact descriptors have been updated to build artifacts for 2.x and the new web application. I have tested the bin and war artifacts and they work ok. I have yet to test any of the extension artifacts.
So in terms of helping out, here is what is left to do:
a) run wms and wcs cite tets
b) test the release artifacts
For b) the regular commands to build the artifacts apply with the added step of ensuring the web2 profile is enabled:
mvn -P release,web2 clean install
mvn assembly:attached
The artifacts will be under target/release
If folks could grab a few of the extension artifacts and test them out that would be a great help.
-Justin
Justin Deoliveira
OpenGeo - http://opengeo.org
Justin Deoliveira ha scritto:
As far as I know there are only two reliable ways to deal with generated
primary keys:
- call Statement.getGeneratedKeys after doing the insertion. This is
   the JDBC standard way to do so, but afaik most databases do not
   implement it, and/or it does not work in all cases, depending
   on the db.
- know what the sequence is, get the next value programmaticaly,
   and use it in the insert. This is the way Hibernate does it, and
   it's reliable among most databases provided you can associate a
   sequence with the pk
Did not check exactly what postgis-ng is doing, but I thought it
was behaving like Hibernate?.
Calling currval and lastval after the insert is certainly wrong,
if the code calling them is not in the same transaction you might get
the wrong id due to other writers pushing the sequence forward before
you can read it (in other words, it will not work in auto commit mode
with concurrent access). Even if you're in the same transaction
accessing sequences might give you the wrong value (e.g., sequences
are never rolled back even if the transaction that moved them
forward is rolled back, so whilst they are guaranteed to never
return the same number, they don't play with transactions the
same way tables do).
I'll give a spin to those two
