[Geoserver-devel] 2.10.0 artifacts are ready to test
Well, what installer does at the moment is to create a one line command to start the Jetty service in the desired port $Port
wrapper.exe -it ./wrapper/wrapper.conf wrapper.java.additional.4=-Djetty.http.port=$Port
I made quite many trials by adding this and that after “wrapper.exe -it ./wrapper/wrapper.conf” with no success.
I believe there are two alternatives:
  1. Find something else than “wrapper.java.additional.4=-Djetty.http.port=$Port” that works on the command line that is launching wrapper.exe.
  2. Make the NSIS to edit the start.ini file. I found a document about replace in file http://nsis.sourceforge.net/ReplaceInFile so it should be possible.
-Jukka Rahkonen-
Lähettäjä: Ian Turton [mailto:ijturton@…403…]
Lähetetty: 27. lokakuuta 2016 13:57
Vastaanottaja: Andrea Aime <andrea.aime@…1268…>
I’ve updated the installer script to make the manual install work - Jukka can you suggest a change for the installer?
Ian
On 27 October 2016 at 10:55, Andrea Aime <andrea.aime@…1268…> wrote:
Hi Ian,
from that doc I see the following:
[user]$ cd jetty-distribution-9.3.14-SNAPSHOT
[jetty-distribution-9.3.14-SNAPSHOT]$ java -jar start.jar --module=http jetty.http.port=8080
Does not look like it should be passed as a system variable using -D, like done in the commit, but plain jane argument instead?
See also:
https://github.com/geoserver/geoserver/commit/dbf7fb7f7f25fd8200aea0f0e3d6611915c19bc8
On Thu, Oct 27, 2016 at 11:32 AM, Ian Turton <ijturton@…403…> wrote:
Looks like they are moving to preferring start.ini over commandline options - https://www.eclipse.org/jetty/documentation/9.3.x/startup.html
Ian
On 27 October 2016 at 10:13, Ian Turton <ijturton@…403…> wrote:
I’m seeing the same thing on my windows box
Ian
On 27 October 2016 at 10:10, Rahkonen Jukka (MML) <jukka.rahkonen@…4189…> wrote:
Unfortunately https://osgeo-org.atlassian.net/browse/GEOS-7677 is not fixed. I found 2 problems:
  1. The wrapper.conf does not get the fourth parameter that was set to be
After installation I have in wrapper.conf just these
Java Additional Parameters
wrapper.java.additional.1=-Djetty.base=.
wrapper.java.additional.2=-DGEOSERVER_DATA_DIR=“%GEOSERVER_DATA_DIR%”
wrapper.java.additional.3=-Djava.io.tmpdir=./work
  1. If I add manually wrapper.java.additional.4=-Djetty.http.port=8089 into wrapper.conf, Geoserver 2.10 still gets installed into port 8080.
So it seems that the fix is not applied but even if it was, if would not correct the issue L
I can make Jetty to start in 8089 if I edit the start.ini file to contain jetty.port=8089. That is an easy fix to do manually, but the script that creates the exe installer does not modify start.ini but only wrapper.conf. I do not know what has changed with the new Jetty. Perhaps the order of applying port definitions from different sources? Now wrapper.conf is trying to set the port to the one that user gives, but both jetty-http.xml and start.ini have the default port 8080. Perhaps another setting overrides whatever is set in wrapper.conf?
-Jukka Rahkonen-
Lähetetty: 27. lokakuuta 2016 11:17
Vastaanottaja: Geoserver-devel
Aihe: [Geoserver-devel] 2.10.0 artifacts are ready to test
Please download your usual package from http://ares.boundlessgeo.com/geoserver/release/2.10.0/ and check it works.
I’d be especially grateful if windows tester could check that GEOS-7808 and GEOS-7677 are now resolved.
Ian
Ian Turton
Ian Turton
Ian Turton
The Command Line: Reinvented for Modern Developers
Did the resurgence of CLI tooling catch you by surprise?
Reconnect with the command line and become more productive.
Learn the new .NET and ASP.NET CLI. Get your free copy!
http://sdm.link/telerik
Geoserver-devel mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Ian Turton
