[Geoserver-devel] 2.10.3 release failing
I’m getting a compile error in the geoserver-release job for 2.10.3:
[ERROR] COMPILATION ERROR :
[INFO] -------------------------------------------------------------
[ERROR] /var/lib/jenkins/workspace/geoserver-release/src/wcs2_0/src/main/java/org/geoserver/wcs2_0/ScalingPolicy.java:[39,39] error: cannot find symbol
[ERROR]  package it.geosolutions.jaiext.utilities
/var/lib/jenkins/workspace/geoserver-release/src/wcs2_0/src/main/java/org/geoserver/wcs2_0/ScalingPolicy.java:[210,18] error: cannot find symbol
[ERROR]  class ImageLayout2
/var/lib/jenkins/workspace/geoserver-release/src/wcs2_0/src/main/java/org/geoserver/wcs2_0/ScalingPolicy.java:[210,44] error: cannot find symbol
/var/lib/jenkins/workspace/geoserver-release/src/wcs2_0/src/main/java/org/geoserver/wcs2_0/ScalingPolicy.java:[334,18] error: cannot find symbol
/var/lib/jenkins/workspace/geoserver-release/src/wcs2_0/src/main/java/org/geoserver/wcs2_0/ScalingPolicy.java:[334,44] error: cannot find symbol
[INFO] 5 errors
Any one have any idea of what to try? restarting didn't help :-(
Ian
Ian Turton
Hi Ian,
it seems that you’ll need a GWC release after all, 1.10.2 for some
reason is depending on an older version of jai-ext, compare:
https://github.com/geoserver/geoserver/blob/2.10.x/src/pom.xml#L1808
with:
https://github.com/GeoWebCache/geowebcache/blob/1.10.2/geowebcache/pom.xml
the latter does not declare the version at all. I guess we looked at the wrong history when checking
if a GWC release was needed, see here:
https://github.com/GeoWebCache/geowebcache/commits/1.10.x/geowebcache
and compare with:
https://github.com/GeoWebCache/geowebcache/commits/1.10.2
It’s actually missing the two last commits, and I believe both are needed for the release to compile…
On Thu, Apr 20, 2017 at 12:36 PM, Ian Turton <ijturton@anonymised.com> wrote:
[INFO] 5 errors
Ian
Ian Turton
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Ok,
I’m looking around to see if I can help with this GWC release in background. I’ll keep you posted (I’m also on gitter)
On Thu, Apr 20, 2017 at 2:06 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Ian,
with:
and compare with:
[INFO] 5 errors
Ian
Ian Turton
Geoserver-devel@anonymised.comrge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
In that case I need an assistant who can push a GWC release. Any volunteers?
Ian
On 20 April 2017 at 13:06, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Ian,
with:
and compare with:
[INFO] 5 errors
Ian
Ian Turton
Ing. Andrea Aime
@geowolf
Technical Lead
Ian Turton
Hi Ian,
after some fighting (the release process does not lend itself to being done in background without paying too much attention)
I have deployed to maven 1.10.3 and SF is underway. Hopefully you’re good to go.
On Thu, Apr 20, 2017 at 2:49 PM, Ian Turton <ijturton@anonymised.com…> wrote:
Ian
Hi Ian,
with:
and compare with:
Ian Turton
[INFO] 5 errors
Ian
Ian Turton
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks
Ian
On 20 April 2017 at 14:46, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Ian,
Ian
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Ian,
with:
and compare with:
Ian Turton
On Thu, Apr 20, 2017 at 12:36 PM, Ian Turton <ijturton@anonymised.com3…> wrote:
[INFO] 5 errors
Ian
Ian Turton
Ing. Andrea Aime
@geowolf
Technical Lead
Ian Turton
