Available on ares please test http://ares.boundlessgeo.com/geoserver/release/2.10-RC1
Jody Garnett
Jody Garnett
I tested geoserver-2.10-RC1-bin.zip with openjdk-8-jdk 8u102-b14.1-2 amd64 on Debian unstable.
I checked artifact sizes and versions for sanity, and GeoServer layer previews and demo requests. The only thing I noticed is that both WPS aggregate demos fail with "HTTP response: 404 Not Found", probably because I did not install the WPS plugin. Perhaps the XML demo requests should mention this requirement in a comment? Everything else looks good.
Kind regards,
Ben.
http://ares.boundlessgeo.com/geoserver/release/2.10-RC1------------------------------------------------------------------------------
Check out the vibrant tech community on one of the world's most
engaging tech sites, SlashDot.org! http://sdm.link/slashdot_______________________________________________
Geoserver-devel mailing list
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/>
New Zealand
Thanks Ben, I tested bin and DMG, release artifacts are up now, with website and blog posts live.
Last steps (available for your volunteer pleasure):
I checked artifact sizes and versions for sanity, and GeoServer layer previews and demo requests. The only thing I noticed is that both WPS aggregate demos fail with “HTTP response: 404 Not Found”, probably because I did not install the WPS plugin. Perhaps the XML demo requests should mention this requirement in a comment? Everything else looks good.
Kind regards,
Geoserver-devel@anonymised.comrge.net
https://lists.sourceforge.net/lists/listinfo/geoserver-devel–
Director
New Zealand
Jody Garnett
Jody,
there is a typo in the GeoWebCache top-level pom (GeoTools "17-SNAPSHOT-SNAPSHOT"):
https://github.com/GeoWebCache/geowebcache/pull/439
There are no GeoWebCache 1.11-SNAPSHOT Maven artifacts until the GeoWebCache build is fixed. This will cause the GeoServer build to fail when you update the dependency versions on master.
Kind regards,
Ben.
website and blog posts live.Last steps (available for your volunteer pleasure):
- email (this is also a call for testing participation)
- fork off 2.10.x so we can end the code freeze (this involves copying a
bunch of jobs on ares)--
Jody GarnettOn 12 October 2016 at 21:02, Ben Caradoc-Davies <ben@anonymised.com> wrote:
on Debian unstable.I checked artifact sizes and versions for sanity, and GeoServer layer
mention this requirement in a comment? Everything else looks good.Kind regards,
https://lists.sourceforge.net/lists/listinfo/geoserver-devel--
Director
New Zealand
Director
New Zealand
Merged
On Fri, Oct 14, 2016 at 2:35 AM, Ben Caradoc-Davies <ben@anonymised.com> wrote:
Jody,
“17-SNAPSHOT-SNAPSHOT”):
https://github.com/GeoWebCache/geowebcache/pull/439There are no GeoWebCache 1.11-SNAPSHOT Maven artifacts until the
when you update the dependency versions on master.Kind regards,
bunch of jobs on ares)–
Geoserver-devel@anonymised.comsourceforge.net
Ben Caradoc-Davies <ben@anonymised.com91…>
Director
New Zealand–
Director
New Zealand
Geoserver-devel@anonymised.com.366…sourceforge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Thanks. The geowebcache-master build is fixed so we should now have 1.11-SNAPSHOT artifacts.
Kind regards,
Ben.
On 14/10/16 20:53, Andrea Aime wrote:
Merged
AndreaOn Fri, Oct 14, 2016 at 2:35 AM, Ben Caradoc-Davies <ben@anonymised.com>
wrote:Jody,
amd64
on Debian unstable.
aggregate demos fail with "HTTP response: 404 Not Found", probablybecause
Director
New Zealand--
Director
New Zealand------------------------------------------------------------
Director
New Zealand
