[Geoserver-devel] 2.13.4 release train needs volunteers
Hello all,
any takers to perform the release around December 18th? :slight_smile:
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Hi Andrea,
I’ll be happy to volunteer for the release but I am busy on the 18th, would it be a problem to postpone the release to the 20th?
Alessandro
On Tue, Dec 11, 2018 at 5:53 PM Andrea Aime <andrea.aime@anonymised.com> wrote:
Hello all,
Geoserver-devel mailing list
Alessandro Parma
Alessandro Parma
DevOps Engineer
No problem about moving the date, it actually happens quite often. I’ll help you out with some of the admin bits (jira releases
and the like)
