[Geoserver-devel] 2.13-RC1 release starting
Following from the GeoTools 19-RC1 and GeoWebCache 1.13-RC1 releases, the GeoServer 2.13-RC1 release process is starting.
I will update here when the artifacts are available for testing.
Torben
GeoServer 2.13-RC1 artifacts available for testing:
https://build.geoserver.org/geoserver/release/2.13-RC1/
Torben
On Wed, Mar 7, 2018 at 1:48 PM, Torben Barsballe <tbarsballe@anonymised.com3839…> wrote:
Torben
Looking at the PDF user manual, I still see the version as 2.12-SNAPSHOT. I think I may have determined where this is getting set: https://github.com/geoserver/geoserver/blob/2.13.x/doc/en/build.xml#L29
Given that this issue has been occurring since sometime in 2.12, perhaps this got broken when we changed the docbuild from using make to maven around the time of the initial 2.12 release.
I’m rerunning the build with a potential workaround, we’ll see if it helps.
Torben.
Torben
On Wed, Mar 7, 2018 at 1:48 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
New build complete, correct version number is now included in the PDF docs: https://build.geoserver.org/geoserver/release/2.13-RC1/geoserver-2.13-RC1-user-manual.pdf
On Wed, Mar 7, 2018 at 2:37 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben.
On Wed, Mar 7, 2018 at 2:22 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
Torben
Tested system-independent binary on OS X, everything seems to be in order.
Proceeding with publish.
On Wed, Mar 7, 2018 at 3:49 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben.
Torben
Torben
RC1 draft blog post here, if anyone wants to take a look: http://blog.geoserver.org/wp-admin/post.php?post=2942&action=edit
Mostly the same as the beta blog post, but added mongodb to the community modules section, and updated the list of bugfixes.
Torben
On Wed, Mar 7, 2018 at 3:59 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben.
Torben
Torben
