I want to ask for permission/comments about back-porting Hierarchical LDAP Groups Support PR to 2.15.x branch, since it is an improvement on LDAP decurity module.
Issue:
https://osgeo-org.atlassian.net/browse/GEOS-9199
PRs:
https://github.com/geoserver/geoserver/pull/3487 (master)
https://github.com/geoserver/geoserver/pull/3506 (2.15.x)
What do you think? Any impediment or doubt about?
Thanks!
Fernando Mino
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Fernando Mino
Software Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Hi Fernando,
can you give us some bearings on the changes?
It seems that the PR only touches the LDAP module, is that correct? Having it isolated in an optional module is
a good starting point
Also, what chance does it have to contain a potential regression for those that are using LDAP without hierarchical structures?
Is the hierarchical code controller by a flag/setting or something?
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Hi Andrea,
Indeed the changes are contained in LDAP module only.
About backward compatibility, the new feature has a boolean configuration flag to activate it (disabled by default) along other related configurations.
This settings are documented on “Authentication with LDAP” tutorial as well:
https://github.com/geoserver/geoserver/blob/0323e17a4179979b1d0b2de7f1a8ed901589e4d1/doc/en/user/source/security/tutorials/ldap/index.rst
Fernando Mino
Hi Fernando,
no objections from me then
