Making a PR auto backport I got a testing failure from build server on 2.15.x branch due to AbstractGridFormat.RESCALE_PIXELS missing symbol:
https://github.com/geoserver/geoserver/blob/2.15.x/src/web/core/src/test/java/org/geoserver/web/data/resource/ResourceConfigurationPageTest.java#L12
RESCALE_PIXELS was committed to 21.x branch recently (on Aug 26):
https://github.com/geotools/geotools/commit/bdac6fbc5f9270fa058439d60137001d663c06a0#diff-e462c902da76b4c19a15e0659773e26a
This failure is reflected on 2.15.x nightly build as well:
https://build.geoserver.org/view/geoserver/job/geoserver-2.15.x-nightly/lastBuild/consoleFull
So probably build server still doesn’t have updated Geotools 21.x dependencies. Can we update them? (I’ll be glad to help if needed).
Fernando Mino
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Fernando Mino
Software Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
