[Geoserver-devel] 2.17.x vs 2.17x branches on github
Hi list,
during a backport, a colleague of mine asked me about the differences between the 2 branches since they contain slightly different commits history.
https://github.com/geoserver/geoserver/tree/2.17.x
https://github.com/geoserver/geoserver/tree/2.17x
Note 2.17.x vs 2.17x (no dot between 17 and x)
The weird thing is that the 2.17x has my name on it :slight_smile:
… “Updated 12 days ago by dromagnoli”
However, the referred update (https://github.com/geoserver/geoserver/commits/2.17x)
comes from a PR against master:
https://github.com/geoserver/geoserver/pull/4142
…“dromagnoli merged 1 commit into geoserver:master from dromagnoli:jai-ext-1.1.14 12 days ago”
Moreover, I don’t have any 2.17x branch locally so, I’m really not sure what’s happened.
We can probably remove that branch.
Daniele
Daniele Romagnoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Daniele Romagnoli
Senior Software Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
I may of been done via the build server as a typo? Please go ahead and remove that branch.
Jody Garnett
Done.
Daniele
Daniele Romagnoli
