On Windows and with AdoptOpenJDK: 11.0.5 (OpenJDK 64-Bit Server VM) I get also a few warnings from org.geoserver.platform.GeoServerExtensions:
WARNING: Extension lookup ‘GeoServerSecurityProvider’, but ApplicationContext is unset.
syysk. 22, 2020 1:16:46 IP. org.geoserver.platform.GeoServerExtensions checkContext
and then this one:
WARNING: Illegal reflective access by org.geotools.image.ImageWorker (file:/C:/ohjelmat/geoserver_218/webapps/geoserver/WEB-INF/lib/gt-coverage-24.0.jar) to constructor com.sun.imageio.plugins.jpeg.JPEGImageWriterSpi()
WARNING: Please consider reporting this to the maintainers of org.geotools.image.ImageWorker
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
Geoserver starts and some requests that I tried with WMS, WFS, and WCS were all right.
-Jukka Rahkonen-
Lähettäjä: Jody Garnett <jody.garnett@…403…>
Lähetetty: tiistai 22. syyskuuta 2020 0.38
Vastaanottaja: Ian Turton <ijturton@…403…>
Kopio: Geoserver-devel geoserver-devel@lists.sourceforge.net
Aihe: Re: [Geoserver-devel] 2,18.0 artifacts to test
Noticed two things:
Testing macOS with war, and extensions mbstyle, ysld, css, wps:
- GEOS-9741 Style editor line numbers overlap with floating validate, save, apply cancel buttons
Testing macOS with bin:
- Startup warnings about:
2020-09-21 14:35:24.060:WARN:oejx.XmlConfiguration:main: Property ‘jetty.port’ is deprecated, use ‘jetty.http.port’ instead
2020-09-21 14:35:24.060:WARN:oejx.XmlConfiguration:main: Property ‘http.timeout’ is deprecated, use ‘jetty.http.idleTimeout’ instead - Startup warning about:
2020-09-21 14:35:24.846:INFO:oejw.StandardDescriptorProcessor:main: NO JSP Support for /geoserver, did not find org.eclipse.jetty.jsp.JettyJspServlet
I don’t think any of these are blockers.
Jody Garnett
On Mon, 21 Sep 2020 at 03:46, Ian Turton <ijturton@…403…> wrote:
https://build.geoserver.org/view/release/job/geoserver-release/12/artifact/distribution/2.18.0/
any windows and mac testers particularly appreciated.
Ian
Ian Turton
Geoserver-devel mailing list
