[Geoserver-devel] [2.2.x] maven tests hangs
I'm working on Windows vista but trying to compile GeoServer 2.2.x with maven and tests enabled the process hangs.
Going to perform individual module tests using eclipse.
I also attached the compile log (sorry for layout it is the git console) and the jstack dump.
Just reporting the problem, I've no time to investigate right now.
Carlo Cancellieri
(attachments)
compile_2.2.x_08112012.log (15.7 KB)
dump.log (16.7 KB)
On Thu, Nov 8, 2012 at 2:14 PM, Carlo Cancellieri
<ccancellieri@anonymised.com> wrote:
Carlo,
GeoServer trunk is known to build on Windows and we have a build
server, but none of
the changes I've made to make it work there have been backported to 2.2.x, so
I'm not surprised it does not build (eventually hanging) on windows
Our support, Your Success! Visit http://opensdi.geo-solutions.it for
more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Carlo,
from time to time I find a naughty test that uses network resources and can end up talking to another concurrent test build (a different branch for example) or a running GeoServer instance. Please ensure no other builds are running and GeoServer is not running on your test instance. If this fixes the problem, you have found a bug; please file a Jira issue because (offline) tests must not use network resources because it breaks isolation.
Kind regards,
Ben.
On 08/11/12 21:14, Carlo Cancellieri wrote:
Carlo Cancellieri
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
