maybe the fix for the logger should be backported and re-included in the release, but up to you…
We are already very late in the release cycle, and we’re back to when we did not have time boxing: release keeps on getting postponed
because we want to add a new thing to it every other day. We already know it does not end well.
I defer to your judgement on what to backport and re-release, but please let’s make sure this is the last bit and
the release is finalized.
Andrea Aime
Lähettäjä: Joseph Miller millerjoseph@anonymised.com Lähetetty: tiistai 24. toukokuuta 2022 19.38 Vastaanottaja: Geoserver-devel geoserver-devel@anonymised.com.net Aihe: [Geoserver-devel] 2.20.x and 2.21.x early backport of [GEOS-10469] and [GEOS-10495]
