Please grab https://build.geoserver.org/view/release/job/geoserver-release/95/artifact/distribution/2.22.1/ and test especially if you are on windows or a Mac
Ian
Ian Turton
Ian
Ian Turton
Bin-zip starts and stops on Windows with Eclipse Adoptium jdk-11.0.17.8-hotspot. I made some simple tests from the UI and did not see anything special. Looks good to me.
-Jukka-
Lähettäjä: Ian Turton <ijturton@anonymised.com03…>
Lähetetty: maanantai 23. tammikuuta 2023 10.14
Vastaanottaja: Geoserver-devel geoserver-devel@anonymised.com.net
Aihe: [Geoserver-devel] 2.21.1 - release artefacts available for testing now
Ian
Ian Turton
The release artifacts for 2.23-RC1 are ready, please grab them and give them a shot
https://build.geoserver.org/view/release/job/geoserver-release/110/artifact/distribution/2.23-RC1/
and test especially if you are on windows or a Mac.
Gabriel Roldán
We are working to restore the windows installer also - which will need testing due to the change to Java 11 minimum.
Jody Garnett
Testing and feedback:
geoserver-2.23-RC1-bin
licenses/ NOTICE.html - looks good
license/GEOTOOLS_NOTICE.html - links to licenses that are not included
README.html - looks good correct date and links
resources/log4j.properties - this can be removed
RUNNING.html - change to java 11 only
Jetty starts, and the logs contain:
2023-03-11 20:45:18.805:WARN:oejw.WebAppContext:main: Failed startup of context o.e.j.w.WebAppContext@anonymised.com{GeoServer,/geoserver,file:///Users/jgarnett/Downloads/geoserver-2.23-RC1-bin/webapps/geoserver/,UNAVAILABLE}{/Users/jgarnett/Downloads/geoserver-2.23-RC1-bin/webapps/geoserver}
java.lang.UnsupportedClassVersionError: org/geoserver/GeoserverInitStartupListener has been compiled by a more recent version of the Java Runtime (class file version 55.0), this version of the Java Runtime only recognizes class file versions up to 52.0
Ideally it would not startup, and have a clear message about Java 11. But we can use the above warning in our release notes.
We are down to only a few GWC warnings:
11 Mar. 20:48:06 WARN [config.XMLConfiguration] - GWC configuration validation error: cvc-elt.1.a: Cannot find the declaration of element ‘gwcConfiguration’.
11 Mar. 20:48:06 WARN [config.XMLConfiguration] - Will try to use configuration anyway. Please check the order of declared elements against the schema.
1
Hi Jody,
thanks for checking. I don’t see anything that would block an RC here, do you?
Better checks for Java 11 could be included in the final
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
Nope, or is an RC so consider this early feedback
That said I do wish to see the windows installer tested for RC, osgeo just got their cert going so we should be able to test before the 18th release.
is their a draft blog post to contribute to?
Jody Garnett
Actually - the windows installer needed a fix on the geoserver side also.
https://github.com/geoserver/geoserver/pull/6670
Can we backport this and re-tag 2.23-RC1 please? With the change to Java 11 it is not the kind of thing I want to see tested for the first time on 2.23.0.
Release candidate is primarily about sorting out build / release kinks after all.
Jody
Jody Garnett
Op zo 12 mrt 2023 om 05:53 schreef Jody Garnett <jody.garnett@anonymised.com3…>:
- Confirming it fails to start in Java 8?
java.lang.UnsupportedClassVersionError: org/geoserver/GeoserverInitStartupListener has been compiled by a more recent version of the Java Runtime (class file version 55.0), this version of the Java Runtime only recognizes class file versions up to 52.0Ideally it would not startup, and have a clear message about Java 11. But we can use the above warning in our release notes.
AFAIK Jetty was not upgraded to a Java 11-only version so that is to be expected, the Jetty container starts first and then the webapp is loaded (which fails as expected)
-M
Hi Mark,
correct, we should upgrade to Jetty 10 indeed. Usual lack of resources dedicated to task…
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
The windows installer is available now: https://build.geoserver.org/view/release/job/geoserver-release/113/artifact/distribution/2.23-RC1/
Thanks to Jaun fixing and testing the script (the files had changed from md to html and the installer script had not been updated yet).
One note is that the installer only recognizes oracle JREs; but you can still choose whatever JRE you have installed.
Jody Garnett
I tried the installer with Adoptium 11.0.8 JDK. No issues to report. Uninstalling left the license directory remaining into “Program Files-GeoServer-license” but otherwise the service was stopped and files removed as they should.
-Jukka Rahkonen-
Lähettäjä: Jody Garnett <jody.garnett@…403…>
Lähetetty: tiistai 14. maaliskuuta 2023 8.57
Vastaanottaja: Andrea Aime <andrea.aime@…6887…>
Kopio: Geoserver-devel geoserver-devel@lists.sourceforge.net
Aihe: Re: [Geoserver-devel] 2.23-RC1 - release artefacts available for testing now
Jody Garnett
Jody
On Sun, Mar 12, 2023 at 10:39 AM Andrea Aime <andrea.aime@…6887…> wrote:
Hi Jody,
2023-03-11 20:45:18.805:WARN:oejw.WebAppContext:main: Failed startup of context o.e.j.w.WebAppContext@…7952…{GeoServer,/geoserver,file:///Users/jgarnett/Downloads/geoserver-2.23-RC1-bin/webapps/geoserver/,UNAVAILABLE}{/Users/jgarnett/Downloads/geoserver-2.23-RC1-bin/webapps/geoserver}
- Check for warnings on initial start
1
- Application appears to be working well in casual testing of layer preview and
Jody Garnett
On Fri, Mar 10, 2023 at 4:31 AM Gabriel Roldan <gabriel.roldan@…403…> wrote:
Gabriel Roldán
Geoserver-devel mailing list
https://lists.sourceforge.net/lists/listinfo/geoserver-devel–
Andrea Aime
GeoServer Professional Services from the experts!Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical LeadGeoSolutions Group
phone: +39 0584 962313fax: +39 0584 1660272
Jody Garnett
Jody Garnett
Thanks, added your feedback to https://osgeo-org.atlassian.net/browse/GEOS-10890
Jody Garnett
I tried the Windows installer and it got stuck on “Writing environment variables” for quite a while, but eventually worked.
Torben
On Tue, Mar 14, 2023 at 9:13 AM Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody GarnettOn Tue, Mar 14, 2023 at 4:37 AM Rahkonen Jukka <jukka.rahkonen@anonymised.com> wrote:
-Jukka Rahkonen-
Lähettäjä: Jody Garnett <jody.garnett@anonymised.com03…>
Vastaanottaja: Andrea Aime <andrea.aime@anonymised.com>
Kopio: Geoserver-devel <geoserver-devel@lists.sourceforge.net>
Aihe: Re: [Geoserver-devel] 2.23-RC1 - release artefacts available for testing nowThe windows installer is available now: https://build.geoserver.org/view/release/job/geoserver-release/113/artifact/distribution/2.23-RC1/
Jody Garnett
On Mon, Mar 13, 2023 at 7:43 AM Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody
On Sun, Mar 12, 2023 at 1:10 PM Jody Garnett <jody.garnett@anonymised.com3…> wrote:
On Sun, Mar 12, 2023 at 10:39 AM Andrea Aime <andrea.aime@anonymised.com7…> wrote:
Hi Jody,
On Sun, Mar 12, 2023 at 5:53 AM Jody Garnett <jody.garnett@anonymised.com> wrote:
1
Jody Garnett
On Fri, Mar 10, 2023 at 4:31 AM Gabriel Roldan <gabriel.roldan@anonymised.com> wrote:
Gabriel Roldán
Andrea Aime
Ing. Andrea Aime
@geowolf
Jody Garnett
Jody Garnett
While we did not have a quorum for today’s meeting; the release notes were updated to thank those doing development and highlight new features and improvements.
https://geoserver.org/announcements/2023/03/14/geoserver-2-23-RC1-released.html
I think it is ready to send to the user list (and twitter? do we still do twitter?)
Jody Garnett
