Hi guys,
I’m writing to request permission for early backport of
https://osgeo-org.atlassian.net/browse/GEOS-10501
It basically adds an entry in the WMS admin section to allow authorization headers forwarding to remote SLDs.
In case a GetMap includes SLD parameter referring to an URL (remote SLD), the authorization headers (if any) provided to that request will be forwarded to the remote URL, but this will only occur if it’s in the allowed list.
The new code path will be only involved once that list gets populated.
Daniele
Daniele Romagnoli
Visit http://bit.ly/gs-services-us for more information.
Daniele Romagnoli
Senior Software Engineer
GeoSolutions Group
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
