[Geoserver-devel] 2.3.x docs
So are we in a no-mans-land between releases where 2.3.x is not yet “stable” and no longer “latest”?
The hudson build job is failing (missing directory) and perhaps should be turned off until 2.3 is released:
  • rm -rf /var/www/html/geoserver/2.3.x/doc/en/user
  • cp -r build/html /var/www/html/geoserver/2.3.x/doc/en/user
    cp: cannot create directory `/var/www/html/geoserver/2.3.x/doc/en/user’: No such file or directory
    [DEBUG] Skipping watched dependency update for build: geoserver-2.3.x-docs #6 due to result: FAILURE
    Finished: FAILURE
Aside: I updated the 2.3.x footer to say 2013 OpenPlans with CCbyA
Jody Garnett
Geospatial Systems Architect
LISAsoft
Ph: +61 2 8570 5000 Fax: +61 2 8570 5099 Mob: +61
Suite 112, Jones Bay Wharf 19-21 Pirrama Rd Pyrmont NSW 2009
LISAsoft is part of the A2end Group of Companies
http://www.ardec.com.au
http://www.lisasoft.com
http://www.terrapages.com
