On Tue, Oct 29, 2013 at 6:20 PM, Jody Garnett <jody.garnett@anonymised.com>wrote:
Changing the security setting to "Allow apps downloaded from Anywhere"
allows GeoServer to run.
So operator error for using OSX.
Any chance Boundless has a key to sign our apps so "Mac App Store and
Identified Developers" setting will work?
Not yet but we are actually working on it. Waiting on apple to "verify our
identity". After which we'll be able to properly sign builds.
Jody Garnett
On 30 October 2013 at 11:04:06 am, Jody Garnett (jody.garnett@anonymised.com<//jody.garnett@anonymised.com>)
wrote:
I downloaded the GeoServer 2.4.1 for testing, resulting in:
We may need to try again.
Jody Garnett
On 22 October 2013 at 1:41:19 pm, Ben Caradoc-Davies (
ben.caradoc-davies@anonymised.com <//ben.caradoc-davies@anonymised.com>) wrote:
Thanks! I have uploaded these remaining artifacts and tested all the
download page links.
Kind regards,
Ben.
On 21/10/13 23:01, Justin Deoliveira wrote:
> Up now, and should hopefully not require manual effort moving forward. I
> worked with a our sysadmin to set up the proper api key and build tokens
> for the installer jobs to be able to fire them off remotely, even though
> the jenkins instances are secured.
> On Sun, Oct 20, 2013 at 8:24 PM, Ben Caradoc-Davies
> <Ben.Caradoc-Davies@anonymised.com <mailto:Ben.Caradoc-Davies@anonymised.com>>
wrote:
> Justin,
> what is the procedure to obtain a .dmg and .exe on the new build
> infrastructure?
> http://ares.boundlessgeo.com/__geoserver/release/2.4.1/
> <http://ares.boundlessgeo.com/geoserver/release/2.4.1/>
> I am updating the release guides as I go.
> Kind regards,
> Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
> Software Engineer
> CSIRO Earth Science and Resource Engineering
> Australian Resources Research Centre
> *Justin Deoliveira*
> Vice President, Engineering | Boundless
> jdeolive@anonymised.com <mailto:jdeolive@anonymised.com>
> @j_deolive <https://twitter.com/j_deolive>
Software Engineer
October Webinars: Code for Performance
Free Intel webinars can help you accelerate application performance.
Explore tips for MPI, OpenMP, advanced profiling, and more. Get the most
from
the latest Intel processors and coprocessors. See abstracts and register >
http://pubads.g.doubleclick.net/gampad/clk?id=60135991&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
- Blank_Skitch_Document.png, 56 KB
*Justin Deoliveira*
(attachments)
