Test with Windows XP, exe-installer and Oracle datastore:
Install OK
Start from Windows start menu OK
Oracle layers from old data directory OK
Stop from Windows start menu OK
What do you mean by - but did not open the config page as I am used to?
I am not used to see any such page.
-Jukka Rahkonen-
Jody Garnett wrote:
Okay a few things are ready for testing:
As usual osx late for the party, we will have to send out a search party.
Testing on windows 7:
install worked okay for me
the start geoserver script worked fin - but did not open the config page as I am used to?
The stop geoserver script did not work, I had to hit control-c in the geoserver window to stop the application
I would like if someone else can test on windows as my environment may be suspect due
Jody
jive
2
When starting geoserver on mac, after the service is started it opens up the geoserver admin panel using the default browser.
On Tue, Sep 3, 2013 at 11:30 PM, Rahkonen Jukka <jukka.rahkonen@anonymised.com> wrote:
Install OK
-Jukka Rahkonen-
Jody
