very pleased to see that this is beeing worked on, it is crucial for us to
be able to disable antialiasing for svg-symbols. ([GEOS-5729] - Antialiasing
can not be turned off for svg-symbols)
Overall, antialiasing for svg-symbols seems to work well, even though I
have not had time yet to look at the quality.
There is, however, one main problem. It seems that antialiasing is not
turned off when a svg-symbol is rotated (see attached picture, yellow and
green ellipses). One strange thing is that two symbols with same sld rule
and svg-symbol might end up both antialiased and none-antialiased in the
same picture (blue ellipses.)
I actually winder if that is antialiasing you are seeing, or just blurbing based on a) drawing the SVG into a an image and then b) drawing the image rotated appropriately? The result would be a slight blurring based on how raster content is drawn …
Learn Graph Databases - Download FREE O’Reilly Book
“Graph Databases” is the definitive new guide to graph databases and their
applications. Written by three acclaimed leaders in the field,
this first edition is now available. Download your free book today! http://p.sf.net/sfu/13534_NeoTech
On Tue, Mar 4, 2014 at 2:43 PM, Jakob Ventin <jventin@anonymised.com> wrote:
Antialiasing
What you see is not antialiasing, it's resampling, rotation make a pixel
that was at an integer position to become a float one, thus it gets
partially painted across 2 to 4 pixels instead.
