so Jody stated, in a deep enough nested thread that I fear nobody noticed,
that the 2.6-beta release is blocked, and he has no more time to work on it.
In a time boxed release model, and also given than in a month and a half
we should be releasing 2.6.0 at FOSS4G, this is a grave situation.
According to Jody:
- the source build does not work
- the installer fails on windows 7
Jody, I’ve looked at the builds and the artifacts, I see no build failures
(well, there is one in the groovy scripting extension, but has an easy fix, and does
not seem to interrupt the artifacts generation),
and the source files are here:
http://ares.boundlessgeo.com/geoserver/release/2.6-beta/geoserver-2.6-beta-src.zip
I had a quick look at the source file, it seems that the file contains
the core module sources, but not the extension file sources? Is that what you have
seen, or are there other issues?
I think this is hardly a blocker for a beta, and as far as I can see, it has
been like this forever, see for example:
http://sourceforge.net/projects/geoserver/files/GeoServer/2.5.1/geoserver-2.5.1-src.zip/download
http://sourceforge.net/projects/geoserver/files/GeoServer/2.4.0/geoserver-2.4.0-src.zip/download
http://sourceforge.net/projects/geoserver/files/GeoServer/2.3.0/geoserver-2.3.0-src.zip/download
So I’d just open a ticket to fix it, and move on.
About the windows installer, I’ve just tried the 2.6-beta installer on one of those Windows 7
VMs that Microsoft gives away to help people test the various versions of IE, where
I previously installed java 7, and indeed I’m getting permission issues.
However, I’ve removed the installer, and installed again with GeoServer running as a service,
and in that case it works fine.
I don’t see how is this specific to this release, I believe every other GeoServer
release has exactly the same issue, and we did not get one report about it on Jira
(http://jira.codehaus.org/issues/?jql=project%20%3D%20GEOS%20AND%20status%20%3D%20Open%20AND%20text%20~%20%22windows%22%20ORDER%20BY%20key%20DESC )
It should definitely be fixed, but I don’t see this as a blocker either, we should just tell
people to install as a service on Windows 7 for the time being and then find someone
that is proficient enough with Windows to fix the installer)
Jody, am I missing any other blocker?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
