2.8.0 artifacts are available for preflight testing:
http://ares.boundlessgeo.com/geoserver/release/2.8.0
Thanks to Kevin for kicking out GWC 1.8.0
I am awaiting to see if the DMG is generated.
Jody Garnett
Jody Garnett
DMG seems to have been generated. Tested DMG on OS X 10.10, and everything looks good.
Torben
On Wed, Sep 30, 2015 at 3:30 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
Geoserver-devel mailing list
Excellent! Thanks to Dave for that
Andrea has started the blog post for GeoServer so we should be able to announce tonight.
On 30 September 2015 at 16:00, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
Jody Garnett
Jody Garnett
I tested the Windows installer with jre 1.8, 32-bit and it looked good.
-Jukka Rahkonen-
Jody Garnett
Thanks so much! The blog post is live and I will send email shortly.
Thanks to Kevin for helping check the blog post, wanted to get it out yesterday so this could still be a September release.
On 1 October 2015 at 06:57, Rahkonen Jukka (MML) <jukka.rahkonen@anonymised.com> wrote:
-Jukka Rahkonen-
Jody Garnett
Jody Garnett
The link on http://geoserver.org/release/2.8.0/ is broken for OGR.
Oh, the 2.7.2 download link on http://geoserver.org/download/ still goes to
2.7.1
Brad
Thanks Brad,
The page is here if you want to fix - https://github.com/geoserver/geoserver.github.io/blob/master/download/index.html#L141
The link on http://geoserver.org/release/2.8.0/ is broken for OGR.Oh, the 2.7.2 download link on http://geoserver.org/download/ still goes to
2.7.1Brad
Jody Garnett
Fixed the one link, not sure about OGR - wonder if OGR made it into the release?
Link goes to: http://sourceforge.net/projects/geoserver/files/GeoServer/2.8.0/extensions/geoserver-2.8.0-ogr-plugin.zip
But I now see geoserver-2.8.0-ogr-wfs-plugin.zip and geoserver-2.8.0-ogr-wps-plugin.zip listed. So yeah not sure what we should be linking to…
2.7.1Brad
Jody Garnett
On Fri, Oct 2, 2015 at 9:51 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
release?Link goes to:
http://sourceforge.net/projects/geoserver/files/GeoServer/2.8.0/extensions/geoserver-2.8.0-ogr-plugin.zipBut I now see geoserver-2.8.0-ogr-wfs-plugin.zip
<http://sourceforge.net/projects/geoserver/files/GeoServer/2.8.0/extensions/geoserver-2.8.0-ogr-wfs-plugin.zip/download>
<http://sourceforge.net/projects/geoserver/files/GeoServer/2.8.0/extensions/geoserver-2.8.0-ogr-wps-plugin.zip/download> listed.
So yeah not sure what we should be linking to...
To both, the page template needs to be modified. I'll see what I can do.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
html#L141
You mean like
https://github.com/geoserver/geoserver.github.io/pull/25
that has been ignored for the last three weeks? And is now obsolete?
Brad
> html#L141
You mean like
Ha... we have some people looking at pull requests for the main repo in
their spare time, but I believe no one is paying attention to the web site
one,
this might explain why nobody noticed
Ing. Andrea Aime
@geowolf
Technical Lead
