I see some warnings in the console window probably after going to Dimensions page of coverage layer which do not have reasonable attributes and UI shows a hint Cannot enable, no attribute of type Date found
I guess that those warnings do not have much value for the users.
23 maaliskuuta 10:39:57 WARN [wicket.Localizer] - Tried to retrieve a localized
string for a component that has not yet been added to the page. This can sometim
es lead to an invalid or no localized resource returned. Make sure you are not c
alling Component#getString() inside your Component’s constructor. Offending comp
onent: [MarkupContainer [Component id = time]]
onent: [MarkupContainer [Component id = elevation]]
23 maaliskuuta 10:40:11 WARN [wicket.Localizer] - Tried to retrieve a localized
onent: [MarkupContainer [Component id = subform]]
-Jukka Rahkonen-
Andrea Aime wrote:
Thanks a ton Jukka, moving on with the release then
On Wed, Mar 23, 2016 at 9:43 AM, Rahkonen Jukka (MML) <jukka.rahkonen@…4189…> wrote:
I tried the Windows exe with ”Oracle Corporation: 1.8.0_20 (Java HotSpot™ 64-Bit Server VM)” and with all default settings. No problem.
-Jukka-
Andrea Aime wrote:
the artifacts are here: http://ares.boundlessgeo.com/geoserver/release/2.8.3/
I’m going to check the bin one, anyone has time to give the windows one
a quick try?
The OSX one (.dmg) seems to be missing in action, I cannot build it myself,
we’ll upload it later if/when it becomes available
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
55054 Massarosa (LU)phone: +39 0584 962313
mob: +39 339 8844549
Transform Data into Opportunity.
Accelerate data analysis in your applications with
Intel Data Analytics Acceleration Library.
Click to learn more.
http://pubads.g.doubleclick.net/gampad/clk?id=278785351&iu=/4140
Geoserver-devel mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
