On Sat, Aug 29, 2015 at 9:35 PM, Jody Garnett <jody.garnett@anonymised.com>
wrote:
Kevin was kind enough to kick out GWC 1.8-beta ...
Sadly our GeoServer build had trouble... this a beta, to ensure that
master is in a releasable state (so consider the following a successful
test, showing we have some release problems):
1) geoserver-release-jira
See #37
<http://ares.opengeo.org/jenkins/view/geoserver/job/geoserver-release-jira/37/console> -
appears to be api difference for new Jira instance, I went with a manual
release.
Could it be that Jira changed its api since last time the script was used
successfully in June? Seems a bit odd.
Maybe the underlying python libs changed instead?
I'm afraid I'm not familiar at all with this bit
2) geoserver-release
See #80
<http://ares.opengeo.org/jenkins/view/geoserver/job/geoserver-release/80/>
Some problems building PDF
Build finished; the LaTeX files are in build/latex.
Run `make all-pdf' or `make all-ps' in that directory to run these
through (pdf)latex.
This is pdfTeX, Version 3.1415926-1.40.10 (TeX Live 2009/Debian)
entering extended mode
libpng error: Not a PNG file
The images in our guide should all be PNGs, LaTeX does not seem to be able
to handle
jpeg or gifs... but afaik those were just warnings.
My guess is something changed and we are not getting the PDF generated
anymore,
but I cannot tell what.
I've tried to build it locally, unfortunately it failed even before, during
make latex in sphinx:
Exception occurred:
File
"/usr/local/lib/python2.7/dist-packages/Sphinx-1.3.1-py2.7.egg/sphinx/writers/latex.py",
line 885, in depart_row
if linestart <= col:
UnboundLocalError: local variable 'col' referenced before assignment
The full traceback has been saved in /tmp/sphinx-err-8I25Zi.log, if you
want to report the issue to the developers.
Please also report this if it was a user error, so that a better error
message can be provided next time.
A bug report can be filed in the tracker at <
https://github.com/sphinx-doc/sphinx/issues>\. Thanks!
Turns out it's this error: https://github.com/sphinx-doc/sphinx/issues/1871
and there is no recent release for me to use... uff... luckly easy_install
allows to install older versions, went back to 1.2.3
Then went to the pdflatex part... fought quite a bit to get all the needed
Latex stuff installed, and reproduced
the same failure as the build box. The actual error is in a log file,
manual.log (from my computer):
!pdfTeX error: pdflatex (file ./server_JAI.png): libpng: internal error
==> Fatal error occurred, no output PDF file produced!
And indeed:
server_JAI.png: PC bitmap, Windows 3.x format, 525 x 674 x 24
Grrr... fixed it, along another file that was committed in that format....
and the found out that Daniele
already changed it back to PNG, got a nice binary conflict... aaah, someone
give me a machete! :-p
Anyways, it's now building on master, and I've committed the fix to the
other BMP file.
You should be good to go, hopefully
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
