[Geoserver-devel] 2.8 needs ojdbc7.jar for 'Exhausted Resultset' error
Ok, took me some time to find out that after upgrading to 2.8 and
working with oracle layers you also really have to upgrade your
ojdbc14.jar ojdbc7.jar from Oracle.
Without upgrading you get an error:
Failure occured while looking up primary key ....
Exhausted Resultset
See also
https://osgeo-org.atlassian.net/browse/GEOT-5098
Is it worth to make a note in the oracle-readme.txt of the oracle plugin
for that (maybe also updating the name of the jar in it)?
Or is that only on Windows?
Happy to do a PR for that...
Richard
On Mon, Oct 5, 2015 at 11:35 AM, Richard Duivenvoorde <rdmailings@anonymised.com.>
Exhausted Resultset
See also
Yep
No, it's generic
Happy to review it then :wink:
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
