[Geoserver-devel] 2.8 Release and GEOS-7124
A couple notes on the 2.8 release scheduled for last week.
We hare having a “bad week” with repo.boundlessgeo.com (and indeed many boundless websites) so I am not sure if everything is stable enough to release today.
Trodden commented on GEOS-7124, but perhaps not strongly enough to reopen the issue and consider the released blocked.
The specific issue is turning using WPS from eclipse (org.geoserver.config.JAIEXTInfo cannot be resolved).
Jody Garnett
On Sat, Sep 26, 2015 at 5:06 PM, Jody Garnett <jody.garnett@anonymised.com>
We hare having a "bad week" with repo.boundlessgeo.com (and indeed many
release today.
Guys, sometimes reading the error messages actually helps: that's what you
get when Eclipse cannot find an import (and as you
might remember, Eclipse compiles and starts anyways, minus throwing an
exception at runtime if you use that portion of the code)
it's a classpath/compile error, has nothing to do with xstream whitelists
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
I got another report from a developer in Victoria, I will hunt down the details on Monday with Kevin.
Have we had any reports of xstream / wps failure coming out of the release candidate? Or just the GWC one Kevin found earlier.
Jody Garnett
On 26 September 2015 at 08:13, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Sat, Sep 26, 2015 at 5:06 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Guys, sometimes reading the error messages actually helps: that’s what you get when Eclipse cannot find an import (and as you
might remember, Eclipse compiles and starts anyways, minus throwing an exception at runtime if you use that portion of the code)
it’s a classpath/compile error, has nothing to do with xstream whitelists
Ing. Andrea Aime
@geowolf
Technical Lead
On Sat, Sep 26, 2015 at 8:37 PM, Jody Garnett <jody.garnett@anonymised.com>
Hum... nope, not sure... the last I heard was from Daniele, but I believe
it was some time ago (like a month ago?)
Ing. Andrea Aime
@geowolf
Technical Lead
I have found these 2 in the past month:
https://osgeo-org.atlassian.net/browse/GEOS-7175
https://osgeo-org.atlassian.net/browse/GEOS-7146
Daniele
On Sat, Sep 26, 2015 at 8:47 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Sat, Sep 26, 2015 at 8:37 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Hum… nope, not sure… the last I heard was from Daniele, but I believe it was some time ago (like a month ago?)
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Daniele Romagnoli
Senior Software Engineer
The recent comments on GEOS-7124 do not represent a blocker, the WPS issues all seem to have been caused by poor documentation.
Created https://osgeo-org.atlassian.net/browse/GEOS-7221 (documentation issue, non-critical).
Tested WPS in eclipse and with 2.8-RC1; no issues.
Torben
On Mon, Sep 28, 2015 at 12:25 AM, Daniele Romagnoli <daniele.romagnoli@anonymised.com> wrote:
Daniele
Geoserver-devel mailing list
On Sat, Sep 26, 2015 at 8:47 PM, Andrea Aime <andrea.aime@anonymised.com.1268…> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
