I made a smoke test with RC1, Windows 10, Oracle jre 8
Installer works and Geoserver starts
For bin-zip I had to set JAVA_HOME manually. The automatic search of jre failed even I let the Java installer to run with all defaults and put Java into the most common place in Program Files. Once jre is found Geoserver starts.
-Jukka Rahkonen-
