[Geoserver-devel] 2.9 release round up
Gathering hit list from yesterdays meeting and emails:
  • Demo Page (GEOS-7513): Niels is looking at using a path (rather than a Resource) to fix the demo page.
  • Demo Page (GEOS-6146): nurc:img_sample2 disabled (either enable or put a comment in the demo request that uses it)
  • windows wrapper (GEOS-7507): testing as admin failed (editing wrapper.conf to match the branch), and we know a win32 jre is needed
To be merged and backported:
  • process factory available check (GEOT-5418) - fixing styling issues and merging/backport
  • 1597 imagemap fix
  • 1589 clustering resource fix
Not included in release:
  • checking use of resource vs file use
  • ldap user/role service
  • layer group virtual service fix
  • tabs vs spaces
Jody Garnett
Update:
- (done) Demo Page (GEOS-7513
<https://osgeo-org.atlassian.net/browse/GEOS-7513&gt;\): Niels is looking at
- (done) Demo Page (GEOS-6146
<https://osgeo-org.atlassian.net/browse/GEOS-6146&gt;\): nurc:img_sample2
- (blocker) windows wrapper (GEOS-7507
<https://osgeo-org.atlassian.net/browse/GEOS-7507&gt;\) - see ticket for updates
- (done) process factory available check (GEOT-5418
<https://osgeo-org.atlassian.net/browse/GEOT-5418&gt;\) - fixing styling issues
- (done) 1597 <https://github.com/geoserver/geoserver/pull/1597&gt; imagemap
fix
- (done) 1589 <https://github.com/geoserver/geoserver/pull/1589&gt; clustering
resource fix
Unplanned:
- (GEOS-7544 <https://osgeo-org.atlassian.net/browse/GEOS-7544&gt;\) importer
filedata use of resource (rather than file)
While looking at Niels’ GEOS-7513 fix, Jody noticed that the ResourceStore work from earlier this year changed the Importer module to use Resource for FileData. This is one place where se shouldn’t be using resource, as FileData represents a file being imported into GeoServer (i.e. not yet in GeoServer). Importer has a seperate comparable object to deal with non-File import sources. I can fix Importer to not use Resource in these places tommorow, but in the mean time we should consider the GeoServer 2.9.0 release blocked.
In addition:
Kevin - are you able to do the GeoWebCachwe release for 1.9.0, given your current injury? If not, are you available to do it Andrea? I believe you have run through the GeoWebCache release before?
Torben
On Wed, May 18, 2016 at 2:53 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
  • 1597 imagemap fix
  • tabs vs spaces
Jody Garnett
Mobile security can be enabling, not merely restricting. Employees who
bring their own devices (BYOD) to work are irked by the imposition of MDM
restrictions. Mobile Device Manager Plus allows you to control only the
apps on BYO-devices by containerizing them, leaving personal data untouched!
https://ad.doubleclick.net/ddm/clk/304595813;131938128;j
Geoserver-devel mailing list
I can see your point, but I am personally not 100% convinced. I understand that the files are not copied to a new location by the importer module and may in fact well already be in the data directory (= the resource store). On the other hand, it does regard data rather than configurations and therefore should not be stored in the jdbcstore, there I agree with you. BUT I thought it could theoretically be possible in the future that the module is also used for configuration files that the user does want to be stored in the jdbcstore. To make things easy, the jdbcstore is equipped to ignore data files inside the data directory and leave them on the hard disk. Therefore it is never really harmful in any way to use resources instead of files, but it allows for more options for the future with less duplicated code. This was the idea behind it. Just my 2 cents.
Kind Regards
Niels
On 20-05-16 02:25, Torben Barsballe wrote:
While looking at Niels' GEOS-7513 fix <https://github.com/geoserver/geoserver/pull/1601&gt;, Jody noticed that the ResourceStore work from earlier this year changed the Importer module to use Resource for FileData. This is one place where se /shouldn't/ be using resource, as FileData represents a file being imported into GeoServer (i.e. not yet in GeoServer). Importer has a seperate comparable object to deal with non-File import sources. I can fix Importer to not use Resource in these places tommorow, but in the mean time we should consider the GeoServer 2.9.0 release blocked.
In addition:
Torben
On Wed, May 18, 2016 at 2:53 PM, Jody Garnett <jody.garnett@anonymised.com <mailto:jody.garnett@anonymised.com>> wrote:
    - Demo Page (GEOS-7513
    - Demo Page (GEOS-6146
    uses it)
    - windows wrapper (GEOS-7507
    <https://osgeo-org.atlassian.net/browse/GEOS-7507&gt;\): testing as
    - process factory available check (GEOT-5418
    - 1597 <https://github.com/geoserver/geoserver/pull/1597&gt; imagemap fix
    - 1589
    resource fix
    - checking use of resource vs file use
    - ldap user/role service
    - layer group virtual service fix
    - tabs vs spaces
    Jody Garnett
    of MDM
    only the
    untouched!
    <mailto:Geoserver-devel@lists.sourceforge.net>
On Fri, May 20, 2016 at 2:25 AM, Torben Barsballe <
Hi Torben,
yep, I've run releases before. The manual process is rather tedious, but
last time I've used a script
by Kevin, we had to do a bit of bug fixing around it but eventually it
worked well:
https://github.com/GeoWebCache/gwc-release
Given the 1.9.x branch exists already, the scenario should be the same as a
normal stable release, so it should
work well again (if not, I'm not exactly good at Ruby, that might be a
problem...) :-p
Let me know when it's time and I can give it a shot
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Dear Jody Garnett
I am currently working on (GEOS-7507) . As Jukka Rahkonen said looks like the problem with jetty temporary directories.
I hope to find the solution quickly.
Alessandro
On 20/05/2016 02:24, Jody Garnett wrote:
Update:
  • (done) Demo Page (GEOS-7513): Niels is looking at using a path (rather than a Resource) to fix the demo page.
  • (done) Demo Page (GEOS-6146): nurc:img_sample2 disabled (either enable or put a comment in the demo request that uses it)
  • (blocker) windows wrapper (GEOS-7507) - see ticket for updates
  • (done) process factory available check (GEOT-5418) - fixing styling issues and merging/backport
  • (done) 1597 imagemap fix
  • (done) 1589 clustering resource fix
    Unplanned:
  • (GEOS-7544) importer filedata use of resource (rather than file)
[https://ad.doubleclick.net/ddm/clk/304595813;131938128;j](https://ad.doubleclick.net/ddm/clk/304595813;131938128;j)
[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
Visit [http://goo.gl/it488V](http://goo.gl/it488V) for more information.
Alessandro Parma
Junior DevOps Engineer
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility  for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
Thanks you Alessandro (both for working on it and on the email coordination).
We currently stand at:
Devon/Jody/Andrea are releasing - in part as Kevin is out of commission for GWC release.
On 20 May 2016 at 02:23, Alessandro Parma <alessandro.parma@anonymised.com> wrote:
Dear Jody Garnett
Alessandro
Alessandro Parma
D.Lgs. 196/2003.
Jody Garnett
Update:
    Unplanned:
Thanks to everyone who helped today.
Open:
  • (GEOS-7507) (Alessandro) tested installer - waiting on pull request
  • (GEOS-7526) (Niels) unique ID appended to the URL - Niels has been unable to reproduce the issue reported with POST URLs
Done:
  • (GEOS-7551) (James) Support for List and Map types in GeoJson
  • (GEOS-7544) (Torben) importer filedata use of resource (rather than file)
  • (GEOS-7549) (Andrea) demo request page
It is a long weekend in Canada so I may be away from internet.
Jody Garnett
Jody Garnett
Jody Garnett
Dear Jody Garnett
Alessandro
Alessandro Parma
D.Lgs. 196/2003.
Update:
    Unplanned:
On Sat, May 21, 2016 at 1:45 AM, Jody Garnett <jody.garnett@anonymised.com>
wrote:
Done:
- (GEOS-7549) (Andrea) demo request page
Not done, only committed against master waiting for the reporter (likely a
security
researcher) to verify it actually works
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Jody,
both the security fix and the installer fix are now in.
On the other side, we found a regression for windows installations with native JAI setup, here:
https://osgeo-org.atlassian.net/browse/GEOS-7554
It has a very quick fix, changing the docs, or might have one that does not change the procedures,
by modifying the Jetty classloading changes, but we haven’t tried that one yet.
For people upgrading GeoServer and having already installed native JAI it would be a regression/upgrade
blocker, fortunately it has a simple fix, I’m just not sure how many would jump on the user list and ask…
On Sat, May 21, 2016 at 10:30 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Sat, May 21, 2016 at 1:45 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Done:
Not done, only committed against master waiting for the reporter (likely a security
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks to both of you.
For GEOS-7554 how about we include these steps in the docs and in the release announcement? Any chance we can catch the exception during start up and provide a more useful error message?
I will start the build tomorrow, or this evening if I get a chance.
Ing. Andrea Aime
@geowolf
Technical Lead
Done:
Ing. Andrea Aime
@geowolf
Technical Lead
On Tue, May 24, 2016 at 2:22 AM, Jody Garnett <jody.garnett@anonymised.com>
Hi Jody,
we did not manage to get this working today, sorry.....
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks, I have documented the workaround (and backed out the status page and geojson changes).
On 24 May 2016 at 09:43, Andrea Aime <andrea.aime@anonymised.com> wrote:
Jody Garnett
On Tue, May 24, 2016 at 2:22 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Hi Jody,
we did not manage to get this working today, sorry…
Ing. Andrea Aime
@geowolf
Technical Lead
