[Geoserver-devel] A bit more parallelism on the build server
as I was fixing the builds on Jenkins this morning I noticed that the java11 build were being queued
and slowing down the JDK8 ones.
Since those are running in their own local repository and are not deploying, I created a new “Java11”
throttling category and set them into that one, alone, this way they can run in parallel with the JDK8 ones.
While I was at it I took the liberty of creating yet another category, “CITE-nightly”, which should allow
to run most builds in parallel with CITE tests, avoiding the common queuing that we see when CITE
do run. The idea is as follows:
  • All CITE tests are in the “CITE-nightly” category only (moved away from the “GeoServer” one)
  • All nightly builds are both in the “GeoServer” and “CITE-nightly” one, preventing them from running concurrently with both normal builds and CITE tests
    This should allow normal builds to run concurrently with CITE tests without disrupting them (they only use nighties as inputs).
There might be some rogue test checking for GeoServer running on 8080 locally, if that happens, we’ll locate it
and make it a true online test
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Thanks, that seems to be making builds go through quite a bit smoother, and everything still seems to be working properly.
On Sat, Oct 27, 2018 at 2:39 AM Andrea Aime <andrea.aime@anonymised.com68…> wrote:
Geoserver-devel mailing list
