Kevin was able to upload GWC to SF, but it has not appeared on repo.boundlessgeo.com - I am going to try and manually upload the jars and see if I can resume the build process.
Jody Garnett
Jody Garnett
There is also another problem: what version of GeoFence are you going to use? I only realised today that GeoFence is a SNAPSHOT dependency. As far as I can tell, geoserver-release does not yet let you pick a revision or release to use. Does 2.9-M0 have a dependency on GeoFence 3.1-SNAPSHOT (master)? That would not be good for a release of any type.
Also, the current GS master does not build against GF master (compile failure in gs-geofence on ares); I am investigating because I want a clean build before switching to Java 8.
Kind regards,
Ben.
Jody Garnett------------------------------------------------------------------------------
Geoserver-devel mailing list
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/>
New Zealand
Geofence is an optional install. This is just a milestone release - we can use it to identify problems like this - but we do not need to stress until the beta
On Sun, Dec 20, 2015 at 4:20 PM Ben Caradoc-Davies <ben@anonymised.com> wrote:
3.1-SNAPSHOT (master)? That would not be good for a release of any type.Also, the current GS master does not build against GF master (compile
clean build before switching to Java 8.Kind regards,
see if I can resume the build process.Jody Garnett
https://lists.sourceforge.net/lists/listinfo/geoserver-devel–
Director
New Zealand
Jody Garnett
Hi Ben,
GeoFence is a dep for the community modules geofence and geofence-server.
If you need I can tag and release a 3.1.0 version, but since it contains some
brand new code I'd like it to be tested a bit.
Please tell me if there are time constraints of any type.
Should be fixed now. Please let me know.
Emanuele
Kind regards,
> Jody Garnett
Ing. Emanuele Tajariol
Technical Lead
Via Poggio alle Viti 1187
mob: +39 380 2116282
I manually deployed the gwc jars that were included in the SF war download.
After doing so the 2.9-M0 release is willing to try and run … but fails partway through:
[INFO] GeoWebCache (GWC) Module … FAILURE [7.064s]
Looks like my manual deploy failed (I asked it to include the pom.xml file from each jar rather than generate one on its own).
[INFO]
[INFO] Building GeoWebCache (GWC) Module 2.9-M0
Downloading: [https://repo.boundlessgeo.com/main/org/geowebcache/gwc-georss/1.9-M0/gwc-georss-1.9-M0.pom
2/2](https://repo.boundlessgeo.com/main/org/geowebcache/gwc-georss/1.9-M0/gwc-georss-1.9-M0.pom
2/2) KB
Downloaded: [https://repo.boundlessgeo.com/main/org/geowebcache/gwc-georss/1.9-M0/gwc-georss-1.9-M0.pom](https://repo.boundlessgeo.com/main/org/geowebcache/gwc-georss/1.9-M0/gwc-georss-1.9-M0.pom) (2 KB at 8.4 KB/sec)
[WARNING] The POM for org.geowebcache:gwc-georss:jar:1.9-M0 is invalid, transitive dependencies (if any) will not be available, enable debug logging for more details
Downloading: [https://repo.boundlessgeo.com/main/org/geowebcache/gwc-gmaps/1.9-M0/gwc-gmaps-1.9-M0.pom
2/2](https://repo.boundlessgeo.com/main/org/geowebcache/gwc-gmaps/1.9-M0/gwc-gmaps-1.9-M0.pom
2/2) KB
Resulting in compilation failures (from missing transitive dependencies):
On 20 December 2015 at 16:05, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
Jody Garnett
>clean build before switching to Java 8.Should be fixed now. Please let me know.
Thanks, Emanuele. Confirmed fixed.
Kind regards,
Director
New Zealand
Now unstuck - thanks for the help aaime
Preflight downloads available: http://ares.boundlessgeo.com/geoserver/release/2.9-M0/
Jody Garnett
Jody Garnett
Mac DMG fails to startup:
WARNING: Module not found [ssl]
2015-12-21 16:29:10.299:INFO::startup executor: Logging initialized @6598ms
2015-12-21 16:29:10.456:INFO:oejs.Server:startup executor: jetty-9.2.13.v20150730
2015-12-21 16:29:10.470:INFO:oejdp.ScanningAppProvider:startup executor: Deployment monitor [file:/Applications/GeoServer.app/Contents/Java/webapps/] at interval 1
2015-12-21 16:29:11.307:INFO:oejw.StandardDescriptorProcessor:startup executor: NO JSP Support for /geoserver, did not find org.eclipse.jetty.jsp.JettyJspServlet
2015-12-21 16:29:11.613:WARN:oejuc.AbstractLifeCycle:startup executor: FAILED o.e.j.w.WebAppContext@anonymised.com{/geoserver,file:/Applications/GeoServer.app/Contents/Java/webapps/geoserver/,STARTING}{/geoserver}: java.lang.NoClassDefFoundError: Could not initialize class javax.media.jai.JAI
at org.geoserver.GeoserverInitStartupListener.contextInitialized(GeoserverInitStartupListener.java:88)
at org.eclipse.jetty.server.handler.ContextHandler.callContextInitialized(ContextHandler.java:800)
Anyone else want to give it a go?
On 21 December 2015 at 16:27, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
Jody Garnett
Jody Garnett
Looking in installed DMG application:
WEB-INF/lib contains:
jai_codec-1.1.3.jar
jai_core-1.1.3.jar
jai_imageio-1.1.jar
Going to try the bin download … same problem:
On 21 December 2015 at 16:31, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
Jody Garnett
Jody Garnett
Jody Garnett
Hi Jody,
if memory serves me well, it sometimes happens that a “NoClassDefFoundError” actually means
“the class is there, but some static initialization failed while loading it”
Do you have any logs, or anything on the standard output?
On Tue, Dec 22, 2015 at 3:39 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
jai_codec-1.1.3.jar
jai_core-1.1.3.jar
jai_imageio-1.1.jarGoing to try the bin download … same problem:
Jody Garnett
Jody Garnett
Jody Garnett
Jody Garnett
Geosolutions’ Winter Holidays from 24/12 to 6/1
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
Thanks for translating …
Here is the console output from starting DMG app: https://www.dropbox.com/s/fq7j3vlk782o515/2.9-M0-cannot-start-logs.txt?dl=0
I could not see a geoserver.log being produced in the data_dir
If I search my system logs for geoserver I find:
Dec 22 12:09:19 Liberi GeoServer[1330]: Option: -DGEOSERVER_DATA_DIR=data_dir
Dec 22 12:09:19 Liberi GeoServer[1330]: Option: -DSTOP.PORT=8079
Dec 22 12:09:19 Liberi GeoServer[1330]: Option: -DSTOP.KEY=geoserver
Dec 22 12:09:19 Liberi GeoServer[1330]: Option: -Xms128m
Dec 22 12:09:19 Liberi GeoServer[1330]: Option: -Xmx512m
Dec 22 12:09:19 Liberi GeoServer[1330]: Option: -XX:MaxPermSize=128m
Dec 22 12:09:19 Liberi GeoServer[1330]: Option: -Dapple.laf.useScreenMenuBar=true
Dec 22 12:09:19 Liberi GeoServer[1330]: Option: -Xdock:icon=Contents/Resources/GeoServer.icns
Dec 22 12:09:34 Liberi GeoServer[1330]: inOptions: {
Dec 22 12:09:34 Liberi GeoServer[1330]: outHitPart = 0
On 22 December 2015 at 01:21, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Jody,
“the class is there, but some static initialization failed while loading it”Do you have any logs, or anything on the standard output?
Jody Garnett
jai_codec-1.1.3.jar
jai_core-1.1.3.jar
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
Jody Garnett
Jody Garnett
Jody Garnett
So yeah, it’s an init error:
However… there is no clue as to what that might be…
Does a bin package start fine?
On Tue, Dec 22, 2015 at 9:13 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
Hi Jody,
jai_codec-1.1.3.jar
jai_core-1.1.3.jar
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
Jody Garnett
Jody Garnett
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
The bin package has the same problem, as indicated a couple emails ago:
I am going to try the bin download again this evening and see if I can get better logs (even just from jetty).
One thing I thought was odd was two ant jars in the jetty lib folder:
ant-1.6.5.jar
ant-1.8.4.jar
ant-launcher-1.8.4.jar
commons-el-1.0.jar
commons-logging-1.1.1.jar
jasper-compiler-5.5.15.jar
jasper-compiler-jdt-5.5.15.jar
jasper-runtime-5.5.15.jar
javax.servlet-api-3.1.0.jar
jetty-deploy-9.2.13.v20150730.jar
jetty-http-9.2.13.v20150730.jar
jetty-io-9.2.13.v20150730.jar
jetty-schemas-3.1.M0.jar
jetty-security-9.2.13.v20150730.jar
jetty-server-9.2.13.v20150730.jar
jetty-servlet-9.2.13.v20150730.jar
jetty-util-9.2.13.v20150730.jar
jetty-webapp-9.2.13.v20150730.jar
jetty-xml-9.2.13.v20150730.jar
jsp-api-2.0.jar
log4j-1.2.14.jar
Not sure if it is significant or not.
On 22 December 2015 at 13:14, Andrea Aime <andrea.aime@anonymised.com> wrote:
Does a bin package start fine?Cheers
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
Hi Jody,
jai_codec-1.1.3.jar
jai_core-1.1.3.jar
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
Jody Garnett
Jody Garnett
Jody Garnett
On Tue, Dec 22, 2015 at 10:21 PM, Jody Garnett <jody.garnett@anonymised.com>
Going to try the bin download ... same problem:
javax.media.jai.JAI
at
at
org.eclipse.jetty.server.handler.ContextHandler.callContextInitialized(ContextHandler.java:800)I am going to try the bin download again this evening and see if I can get
better logs (even just from jetty).One thing I thought was odd was two ant jars in the jetty lib folder:
ant-1.6.5.jar
ant-1.8.4.jar
commons-el-1.0.jar
jsp-api-2.0.jar
log4j-1.2.14.jarNot sure if it is significant or not.
That seems at least wrong, and should be rectified, but I'm not sure which
ant jar
is needed by Jetty, a stand alone installation should be checked.
Did you try removing one of those and see if that cures your startup?
*Geosolutions' Winter Holidays from 24/12 to 6/1*
Ing. Andrea Aime
@geowolf
Technical Lead
I have not experimented yet, was going to compare to prior releases.
On 24 December 2015 at 08:55, Andrea Aime <andrea.aime@anonymised.com> wrote:
Jody Garnett
On Tue, Dec 22, 2015 at 10:21 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
at org.eclipse.jetty.server.handler.ContextHandler.callContextInitialized(ContextHandler.java:800)I am going to try the bin download again this evening and see if I can get better logs (even just from jetty).
ant-1.6.5.jar
ant-1.8.4.jar
commons-el-1.0.jar
jsp-api-2.0.jar
That seems at least wrong, and should be rectified, but I’m not sure which ant jar
Ing. Andrea Aime
@geowolf
Technical Lead
On Thu, Dec 24, 2015 at 5:57 PM, Jody Garnett <jody.garnett@anonymised.com>
Hum... not sure you have much to compare to, M0 is getting released also
because
Jetty was upgraded, and thus not the same as in the previous releases, no?
Ing. Andrea Aime
@geowolf
Technical Lead
Okay got a lead … the bin download has the same list of jars (two ant jars etc…)
I moved the JAI jars (jai_codec-1.1.3.jar, jai_core-1.1.3.jar,jai_imageio-1.1.jar) from webapps/geoserver/WEB-INF/libs to the jetty libs folder - and now the application can start up (and appears to function).
The logs of this startup are here https://www.dropbox.com/s/687mevu083w1fpd/2.9-M0-bin-hack-logs.txt?dl=0
I am going to assume that we need to mess with the new jetty configuration / classpath (rather than move jars around).
For reference the jetty lib folder now contains:
On 24 December 2015 at 09:00, Andrea Aime <andrea.aime@anonymised.com> wrote:
Jody Garnett
On Thu, Dec 24, 2015 at 5:57 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Hum… not sure you have much to compare to, M0 is getting released also because
Ing. Andrea Aime
@geowolf
Technical Lead
Justin it looks like 2.9-M0 was not tagged by ares release script (sigh).
Here are the revisions used for the release:
version = 2.9-M0
git revision = 577f89dfd3c7302dae1b84f0e95e145322f94ed6
git branch = 577f89dfd3c7302dae1b84f0e95e145322f94ed6
build date = 17-Dec-2015 08:01
geotools version = 15-M0
geotools revision = fe28f403c9008d39a70b8d5f1b12340b46b875c7
geowebcache version = 1.9-M0
geowebcache revision = 8d9a56855f56f25e73eb3866c275dc49dd793335/8d9a5
hudson build = -1
geotools=15-M0
geowebcache=1.9-M0
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
Hey Jody.
Thanks for the revision info. I checked out and built everything locally and I was able to build a working mac installer without issue. No jetty problems… So not sure, perhaps the installer relies on something specific to my setup, not sure. Let’s debug your setup.
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
Update for the list, the new DMG was picking up java extensions from ~/Library/Java/Extensions (since I had the mac JAI installed it hated me). While this is an unexpected change from the 2.8.x branch we have been able to hack around the problem by supplying our own java.ext.dir (and ignoring the default one).
So good to go on OSX.
(We will still have a bit of work for the 2.9-beta - namely updating the windows and mac installers to Java 8)
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
