On Tue, Dec 22, 2015 at 9:10 AM, Rahkonen Jukka (MML) <
jukka.rahkonen@anonymised.com> wrote:
Both Windows installer and binary zip versions fail for me.
The error from Windows installer version is:
C:\Program Files (x86)\GeoServer 2.8.0\bin>startup
C:\Program Files (x86)\GeoServer 2.8.0\bin>call "C:\Program Files
(x86)\Java\jre
1.8.0_60\bin\java.exe" -DGEOSERVER_DATA_DIR="C:\Program Files
(x86)\GeoServer 2.
8.0\data_dir" -Xmx512m -XX:MaxPermSize=128m -DSTOP.PORT=8079
-DSTOP.KEY=geoserve
r -Djetty.port=8080 -Djetty.logs="C:\Program Files (x86)\GeoServer
2.8.0\logs" -
jar "C:\Program Files (x86)\GeoServer 2.8.0\start.jar"
Java HotSpot(TM) Client VM warning: ignoring option MaxPermSize=128m;
support wa
s removed in 8.0
WARNING: Module not found [ssl]
WARNING: Nothing to start, exiting ...
The directory “C:\Program Files (x86)\GeoServer 2.8.0” is right, installer
puts M0 there with the default settings.
Wondering, did you choose it, or did the program suggest it?
Log from the binary zip trial is in the attachment.
From the log:
"Found System environment variable GEOSERVER_DATA_DIR set to C:\Program
Files (x86)\GeoServer 2.8.0\data_dir , but this path does not exist"
Hum... was the installation incomplete, it seems the data dir is not there?
Everything went downhill from there it seems
*Geosolutions' Winter Holidays from 24/12 to 6/1*
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
