[Geoserver-devel] a bit stuck on 2.9-M0 release
All right, binary zip starts now when I deleted the old GEOSERVER_DATA_DIR environment setting. The problem is that if environment is set to non-existing data directory then:
“Falling back to embedded data directory: C:\ohjelmat\geoserver-2.9-M0\webapps\geoserver\data”
However, zip file does not expand data directory under webapps but into : C:\ohjelmat\geoserver-2.9-M0\data_dir.
After I uninstalled GS 2.8.0 the Windows installer now installs M0 into C:\Program Files (x86)\GeoServer 2.9-M0 if I just accept everything that the installer is suggesting. It does not start though, but ends to Nothing to start:
C:\Program Files (x86)\GeoServer 2.9-M0\bin>call “C:\Program Files (x86)\Java\jre1.8.0_60\bin\java.exe”
-DGEOSERVER_DATA_DIR=“C:\Program Files (x86)\GeoServer 2.9-M0\data_dir”
-Xmx512m -XX:MaxPermSize=128m -DSTOP.PORT=8079 -DSTOP.KEY=geoserver -Djetty.port=8080
-Djetty.logs=“C:\Program Files (x86)\GeoServer 2.9-M0\logs” -jar “C:\Program Files (x86)\GeoServer 2.9-M0\start.jar”
Java HotSpot™ Client VM warning: ignoring option MaxPermSize=128m; support was removed in 8.0
WARNING: Module not found [ssl]
WARNING: Nothing to start, exiting …
Usage: java -jar start.jar [options] [properties] [configs]
java -jar start.jar --help # for more information
-Jukka-
andrea aime wrote:
On Tue, Dec 22, 2015 at 9:10 AM, Rahkonen Jukka (MML) <jukka.rahkonen@…4189…> wrote:
Both Windows installer and binary zip versions fail for me.
The error from Windows installer version is:
C:\Program Files (x86)\GeoServer 2.8.0\bin>startup
C:\Program Files (x86)\GeoServer 2.8.0\bin>call "C:\Program Files (x86)\Java\jre
1.8.0_60\bin\java.exe" -DGEOSERVER_DATA_DIR="C:\Program Files (x86)\GeoServer 2.
8.0\data_dir" -Xmx512m -XX:MaxPermSize=128m -DSTOP.PORT=8079 -DSTOP.KEY=geoserve
r -Djetty.port=8080 -Djetty.logs=“C:\Program Files (x86)\GeoServer 2.8.0\logs” -
jar “C:\Program Files (x86)\GeoServer 2.8.0\start.jar”
s removed in 8.0
The directory “C:\Program Files (x86)\GeoServer 2.8.0” is right, installer puts M0 there with the default settings.
Wondering, did you choose it, or did the program suggest it?
Log from the binary zip trial is in the attachment.
From the log:
“Found System environment variable GEOSERVER_DATA_DIR set to C:\Program Files (x86)\GeoServer 2.8.0\data_dir , but this path does not exist”
Hum… was the installation incomplete, it seems the data dir is not there?
Everything went downhill from there it seems
Geosolutions’ Winter Holidays from 24/12 to 6/1
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
