ever wanted to have a color chooser in the editor instead of having to go to external tools?
Here:
A small video demonstrating how it works (notice how you can select a color in the source,
view it the picker, and change it):
https://drive.google.com/open?id=1XGCfQnLOJ902_9SYhGU1Kx5JtNWqbq4a
And of course, the pull request:
https://github.com/geoserver/geoserver/pull/2921
A few things:
- Has anyone time to try it out and tell me if it works fine on their machines? I had some troubles setting up the size of the dialog, not sure it’s going to work fine on other machines.
- As usual I’ve struggled a bit with the javascript/wicket integration, further improvements by people more skilled than me at that more than appreciated :-p
- Tests on browsers other than Chrome/Firefox would also be useful.
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Nice, thanks !
I tested this on Windows 7, with Edge \ IE and it works fine:
(attachments)
Nuno Oliveira
On 06/17/2018 03:22 PM, Andrea Aime wrote:
Here:
A few things:
Check out the vibrant tech community on one of the world's most
engaging tech sites, Slashdot.org! [http://sdm.link/slashdot](http://sdm.link/slashdot)
Geoserver-devel mailing list
[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
Nuno Oliveira
Visit [http://goo.gl/it488V](http://goo.gl/it488V) for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
