[Geoserver-devel] A problem on Geoserver1.4.0
I downloaded the geoserver-1.4.0-war.zip from http://docs.codehaus.org/display/GEOS/Latest. I decompressioned the zip file and copy the geoserver.war file to tomcat folder. When I started the tomcat, I found the geoserver can not run normally.
新年祝福短信免费发
That release was tested against tomcat and worked fine.
To double check, I did download from sourceforge me too, and dropped
the war in tomcat apache-tomcat-5.5.20 with jdk 1.5.0_09 (since
that tomcat version cannot run with jdk 1.4.2). Worked just fine.
What do you have in the tomcat logs? Which version of tomcat are you
using?
