Could you send these questions to the devel list? geoserver@anonymised.com
is more for information about geoserver, not debugging. Sending to
this list ensures that all developers will get it (including Gabriel,
the author of the arcsde datastore, and Andrea, the author of the
LiteRenderer). One question, do you get the same errors when working
with the svg-xml image type? It uses different rendering, and thus if
you do not get the same problem then we can isolate it to the
LiteRenderer.
Chris
----- Forwarded message from huohong <huohong@anonymised.com> -----
Date: Fri, 26 Mar 2004 16:37:09 +0800
Reply-To: huohong <huohong@anonymised.com>
Subject: a question about zoomin and zoomout
To: geoserver@anonymised.com
I have a question about geoserver.That is£º
original BBOX size
-25858,1309,-12447,14936
1.
org.vfny.geoserver.requests.readers.KvpRequestReader - returning parsed
{SRS=EPSG:21421, EXCEPTIONS=INIMAGE, BBOX=-25858,1309,-12447,14936,
LAYERS=cgf:SDE.R90020001, HEIGHT=400, REQUEST=GetMap, STYLES=blue,
WIDTH=400, FORMAT=image/png, TRANSPARENT=TRUE}
org.vfny.geoserver.responses.wms.map.JAIMapResponse - holly test:
bbox.minx=-25858.0
bbox.maxx=-12447.0
bbox.miny=1309.0
bbox.maxx=14936.0
org.geotools.renderer.lite.LiteRenderer - Rendered 16 features in 0.125
sec.
2.
BBOX=-21499.425,3949.23125,-14793.925,10762.73125,
bbox.minx=-21499.425
bbox.maxx=-14793.925
bbox.miny=3949.23125
bbox.maxx=10762.73125
org.geotools.renderer.lite.LiteRenderer - Rendered 14 features in 0.031
sec.
3.
BBOX=-19487.774999999997,5269.346875000002,-15632.1125,9187.109375,
bbox.minx=-19487.774999999998
bbox.maxx=-15632.1125
bbox.miny=5269.346875000002
bbox.maxx=9187.109375
org.geotools.renderer.lite.LiteRenderer - Rendered 7 features in 0.016
sec.
4.
BBOX=-18861.22984375,5661.123125000001,-15776.699843749998,8795.333125000001,
bbox.minx=-18861.22984375
bbox.maxx=-15776.699843749999
bbox.miny=5661.123125000001
bbox.maxx=8795.333125000001
sec.
5.
BBOX=-18437.10696875,7796.303687500002,-17704.53109375,8540.6785625,
bbox.minx=-18437.10696875
bbox.maxx=-17704.53109375
bbox.miny=7796.303687500002
bbox.maxx=8540.6785625
org.geotools.renderer.lite.LiteRenderer - Rendered 16 features in 0.0
sec.
6.
BBOX=-18235.648603125,8340.62781484375,-18226.4914046875,8349.93250078125,
org.geotools.data.sde.SDEQuery - Trying to close an SeQuery: NETWORK I/O
OPERATION FAILED.
After I¡¡zoom in or zoom out for 5 times,Geoserver will throw the error(
I use the Arcsde datastore):
org.geotools.data.sde.SdeAdapter - Encoder errorCannot apply spatial
constraints: NETWORK I/O OPERATION FAILED.
org.geotools.data.DataSourceException: Encoder errorCannot apply spatial
at org.geotools.data.sde.SdeAdapter.createSeQuery(SdeAdapter.java:443)
at
org.geotools.data.sde.SdeAdapter.createSeQuery(SdeAdapter.java:344)......
I don't the reason.Would you help me ? Is that the BBOX has some
limit?If there is no feature in the BBOX or BBOX is too small ,it will
throw errors?
Thank you very much for your reply!
best wishes
holly
----- End forwarded message -----
This mail sent through IMP: https://webmail.limegroup.com/
