[Geoserver-devel] "A Simple Plugin" example possible without Geoserver build?
Over the last few weeks, I've made repeated attempts to build the
GeoServer source, without success.
Since I'm coming to the end of the time I've got allocated for this and
(at least initially), all I want to do is build the "Simple Plugin"
example:
http://docs.codehaus.org/display/GEOSDOC/3+A+Simple+PlugIn
is it possible to achieve this using the geoserver binary distribution?
I ask because the AbstractService class (for example) appears to be
absent from the bundled jarfiles.
Jerry.
This message has been checked for viruses but the contents of an attachment
may still contain software viruses, which could damage your computer system:
you are advised to perform your own checks. Email communications with the
University of Nottingham may be monitored as permitted by UK legislation.
Hi Jerry,
Thats too bad about not being able to build GeoServer from sources. From your previous messages it seems that you are building the trunk sources. The tutorial listed below works against the 1.5.x version of geoserver and below and seems to be written against 1.4.x.
You should not need to build geoserver sources to run the tutorial. The version ( 1.4.0-M0 ) of which the tutorial is written against is posted is available in the maven repository ( specified in the pom in the tutorial ). So all the geoserver binaries will be downloaded when you compile your plugin.
Let me know if you have any problems.
-Justin
example:
Jerry.
opinions on IT & business topics through brief surveys-and earn cash
Geoserver-devel mailing list
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
