By following the advice in Andrea's last reply, I'm happy to say that
I've successfully built the hello example using the 1.5.x checkout she
described.
Presumably the next step is for me to get the hello example working
using Eclipse...?
In the light of this, would it be better for me in the longer term to be
working with geoserver-1.5.0-rc2 (as per the discussion below), or
should I stick with what I've got working?
Jerry.
-----Original Message-----
From: Justin Deoliveira [mailto:jdeolive@anonymised.com]
Sent: 27 March 2007 18:09
To: Swan Jerry
Cc: Andrea Aime; geoserver-devel@lists.sourceforge.net
Subject: Re: [Geoserver-devel] "A Simple Plugin" example possible
without Geoserver build?
Hi Jerry,
I have made sure all the necessary dependencies are in the repository
now. I also made a small modification to the pom in the tutorial to add
the refractions repository.
-Justin
Swan Jerry wrote:
Hum, did you do a mvn install in the community folder?
Ok, I'm using the version of "hello" that checks out as
geoserver-1.5.0-rc2/geoserver/community/hello
mvn install in the community folder gives the output below. Should I
be looking to change the version number in the community pom?//////////////////////////////////////////////////////////////////////
///////[INFO] Scanning for projects...
[INFO]
[ERROR] FATAL ERROR
[INFO]
[INFO] Failed to resolve artifact.GroupId: org.geoserver
ArtifactId: geoserver
Version: 1.6-SNAPSHOTReason: Unable to download the artifact from any repository
org.geoserver:geoserver:pom:1.6-SNAPSHOT
from the specified remote repositories:
central (http://repo1.maven.org/maven2)[INFO]
[INFO] Trace
org.apache.maven.reactor.MavenExecutionException: Cannot find parent:
org.geoser
ver:geoserver for project: org.geoserver:community:pom:1.6-SNAPSHOT
at
org.apache.maven.DefaultMaven.getProjects(DefaultMaven.java:365)
at
org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:278)
at
org.apache.maven.DefaultMaven.execute(DefaultMaven.java:115)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:256)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.
java:39)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces
sorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:324)
at
org.codehaus.classworlds.Launcher.launchEnhanced(Launcher.java:315)
at org.codehaus.classworlds.Launcher.launch(Launcher.java:255)
at
org.codehaus.classworlds.Launcher.mainWithExitCode(Launcher.java:430)at org.codehaus.classworlds.Launcher.main(Launcher.java:375)
Caused by: org.apache.maven.project.ProjectBuildingException: Cannot
find parent
: org.geoserver:geoserver for project:
at
org.apache.maven.project.DefaultMavenProjectBuilder.assembleLineage(D
efaultMavenProjectBuilder.java:1161)
at
efaultMavenProjectBuilder.java:1176)
at
org.apache.maven.project.DefaultMavenProjectBuilder.buildInternal(Def
aultMavenProjectBuilder.java:674)
at
org.apache.maven.project.DefaultMavenProjectBuilder.buildFromSourceFi
leInternal(DefaultMavenProjectBuilder.java:416)
at
org.apache.maven.project.DefaultMavenProjectBuilder.build(DefaultMave
nProjectBuilder.java:192)
at
org.apache.maven.DefaultMaven.getProject(DefaultMaven.java:515)
at
org.apache.maven.DefaultMaven.collectProjects(DefaultMaven.java:447)
at
org.apache.maven.DefaultMaven.collectProjects(DefaultMaven.java:491)
at
org.apache.maven.DefaultMaven.getProjects(DefaultMaven.java:351)
... 11 more
Caused by: org.apache.maven.project.ProjectBuildingException: POM
'org.geoserver :geoserver' not found in repository: Unable to download
the artifact from any re pository
central (http://repo1.maven.org/maven2)at
org.apache.maven.project.DefaultMavenProjectBuilder.findModelFromRepo
sitory(DefaultMavenProjectBuilder.java:513)
at
efaultMavenProjectBuilder.java:1157)
... 19 more
Caused by:
org.apache.maven.artifact.resolver.ArtifactNotFoundException:
Unable
to download the artifact from any repositoryorg.geoserver:geoserver:pom:1.6-SNAPSHOT
org.apache.maven.artifact.resolver.DefaultArtifactResolver.resolve(De
faultArtifactResolver.java:136)
at
faultArtifactResolver.java:63)
at
sitory(DefaultMavenProjectBuilder.java:467)
... 20 more
Caused by: org.apache.maven.wagon.ResourceDoesNotExistException:
Unable to downl oad the artifact from any repository
at
org.apache.maven.artifact.manager.DefaultWagonManager.getArtifact(Def
aultWagonManager.java:260)
at
faultArtifactResolver.java:124)
... 22 more
[INFO]
[INFO] Total time: < 1 second
[INFO] Finished at: Tue Mar 27 12:11:20 BST 2007 [INFO] Final Memory:
1M/3M [INFO]
--Jerry.
Sent: 27 March 2007 10:34
To: Swan Jerry
Cc: Justin Deoliveira; Geoserver-devel
without Geoserver build?Swan Jerry ha scritto:
Thats too bad about not being able to build GeoServer from sources.
The possibility that it's because I'm doing something stupid is ever
presentLet me know if you have any problems.
Following the tutorial verbatim (but removing the text "ur file
system"
from line 11 of pom.xml), mvn install gives me the following:
Downloading:
http://repository.codehaus.org//org/geoserver/community/1.4.0-M0/co
mmunity-1.4.0-M0.pom
[WARNING] Unable to get resource from repository codehaus
(http://repository.cod
ehaus.org/)
Downloading:
http://repo1.maven.org/maven2/org/geoserver/community/1.4.0-M0/comm
unity-1.4.0-M0.pom
[WARNING] Unable to get resource from repository central
/maven2)
[INFO]
[ERROR] FATAL ERROR
[INFO]
ArtifactId: community
Version: 1.4.0-M0Reason: Unable to download the artifact from any repository
org.geoserver:community:pom:1.4.0-M0
If not, you need to, if yes, the pom.xml in that folder has probably a
wrong version number?
AndreaThis message has been checked for viruses but the contents of an
attachment may still contain software viruses, which could damage your
computer system:
you are advised to perform your own checks. Email communications with
the University of Nottingham may be monitored as permitted by UK
legislation.
--- Take Surveys. Earn Cash. Influence the Future of IT Join
SourceForge.net's Techsay panel and you'll get the chance to share
your opinions on IT & business topics through brief surveys-and earn
cash
http://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEV
DEV _______________________________________________
Geoserver-devel mailing list
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
This message has been checked for viruses but the contents of an attachment
may still contain software viruses, which could damage your computer system:
you are advised to perform your own checks. Email communications with the
University of Nottingham may be monitored as permitted by UK legislation.
