[Geoserver-devel] A Wicket test utility
trying to test Wicket pages or components I find it sometimes
annoying to try and figure out the paths of various components.
Yes, we have the possibility to get the paths from the UI itself,
but when testing a component in isolation or a page that
can reached only with a long workflow, I feel it would be better
to have a more direct way.
In the spirit of the print(dom) utility that we have to dump
down a xml document returned by GeoServer services, I think
it would be nice to have a print(Component/Page) that prints
in text the component hierarchy, with ids, visibility status,
and eventually the model values, something like:
form
   name [John]
   surname [Doe]
   hiddenField (h) [secret]
where the value is in square brackets and (h) marks
hidden components. We could also consider adding
a third param like the component class (optional,
so it would be print(component, showClasses, showValues))
What do you think?
I looked around but could not find such an utility
already made.
Andrea Aime
OpenGeo - http://opengeo.org
+1, sounds like a useful thing to have. We already have a base test class for UI tests right? GeoServerWebTestSupport or something.
Andrea Aime wrote:
form
   name [John]
   surname [Doe]
What do you think?
already made.
Justin Deoliveira
GeoServerWicketTestSupport, which with the extra printing
method would become GeoServerAwesomeWicketTestSupport :wink:
Andrea Aime
Done.
I added a WicketHierarchyPrinter class in web2/core/src/main,
org.geoserver.web.wicket package,this allows one to use it for interactive debugging purposes too if needed.
It can be used by its utility method
WicketHierarchyPrinter.print(Component c, boolean dumpClass, boolean dumpValue)
from anywhere in the code, GeoServerWicketTestSupport also
provides its own
that delegates to the above for shortness.
I've attached a sample output of it against NewLayerPage configured
with a store, minimal.txt contains just the ids and classes,
full.txt also the model values.
Feedback appreciated
Andrea Aime
(attachments)
minimal.txt (13.2 KB)
full.txt (17.2 KB)
