Ciao Jody,
please, read below...
Simone Giannecchini
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Thu, Jun 25, 2015 at 4:39 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
No I understand, and I agree we should ask for bug fixes to be back ported.
I can even add this to my list of dev guide changes fit Geoserver.
Beyond that I am trying to see what kind of fixes we are missing. I know
Boundlesd staff would often focus on 2.7. I often focus just on GeoTools
master.
And 2.6?
This attitude makes 2.6 useles since fixes are not ported over.
Is there any way we can improve our game and make this easier. Like discuss
backports when the fix is a pull request?
I believe my position is clear, fixes _must_ be backported otherwise 3
branches are useless.
I know it is a strong statement, but we need to find a (cooperative)
way to make this happen.
Just stating that if someone provides a fix he must also provide
backports might be too strong (although I would prefer it over
free will) hence I am open to see alternatives. On the other side,
discussing on the ML each single fix seems an overkill to me.
At the very least I believe that we shall ask people to investigate
and report on whether a fix can be backported and then encourage to do
the backport.
I would like to make the backport mandatory but it might be better to
make it recommended.
At the very least we need to make everyone responsible for:
-1- investigating if the issue impact all the active branches
-2- investigating whether a fix is possible
-3- capturing this in jira
Actual backporting can stay a volunteer based action for the time
being, I am keen in spending some of our time on doing that.
On Thu, Jun 25, 2015 at 12:50 AM Andrea Aime <andrea.aime@anonymised.com>
wrote:
On Thu, Jun 25, 2015 at 9:41 AM, Simone Giannecchini
<simone.giannecchini@anonymised.com> wrote:
Long story short, IMHO no regular backports might lead to less
meaningful mantenaince releases.
I believe he means, no regular backports of bug fixes
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il loro
utilizzo è consentito esclusivamente al destinatario del messaggio, per le
finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
via e-mail e di procedere alla distruzione del messaggio stesso,
cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
finalità diverse, costituisce comportamento contrario ai principi dettati
dal D.Lgs. 196/2003.
information in this message that has been received in error. The sender does
not give any warranty or accept liability as the content, accuracy or
Jody Garnett
