[Geoserver-devel] about GEOS:3824: Improve the GDAL-ImageIO-Ext section User Documentation
Hi list, some weeks ago I have added a patch to GeoServer’s JIRA in order to improve GDAL related documentation.
The past week I have posted a new one also adding the tips to run GeoServer as a windows service.
Since it is a trivial add to the doc and no-one worked on it yet, can I assign it to myself and commit?
If someone can give me a +1 I will go on.
Best Regards,
Daniele
Eng. Daniele Romagnoli
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 328 0559267
I haven't had much of any time to go over doc patches, so I apologize. I am curious about your tips to run GeoServer as a Windows Service...is there something that the installer doesn't do that it should?
Mike Pumphrey
OpenGeo - http://opengeo.org
On 4/6/2010 11:26 AM, Daniele Romagnoli wrote:
Hi list, some weeks ago I have added a patch to GeoServer's JIRA in
Best Regards,
Daniele
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Download Intel® Parallel Studio Eval
Try the new software tools for yourself. Speed compiling, find bugs
proactively, and fine-tune applications for parallel performance.
See why Intel Parallel Studio got high marks during beta.
http://p.sf.net/sfu/intel-sw-dev
Geoserver-devel mailing list
Hi Mike,
On Tue, Apr 6, 2010 at 5:33 PM, Mike Pumphrey <mike@anonymised.com> wrote:
I haven’t had much of any time to go over doc patches, so I apologize.
No problem on this.
I am curious about your tips to run GeoServer as a Windows Service…is there something that the installer doesn’t do that it should?
As users noticed with some emails in the past, the standard installation of GeoServer as a Windows Service doesn’t allow to see the GDAL native libs (when available) and then there is no GDAL formats support. After investigation, I have found a solution for this (See 1) and I have added it to the geoserver’s doc. Honestly, I don’t know how the installer works with extensions and optional elements. A look on the solution can give you better details on what I have found and what the installer could perhaps do.
Hope this helps. Let me know if you need additional info.
Daniele
Mike Pumphrey
Best Regards,
Daniele
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Thanks for finding a workaround. Is there a standard, optimal, default place where the instructions say to put the nativelibs? I could incorporate a path check into the installer. Please open a JIRA and assign it to me.
Mike Pumphrey
On 4/6/2010 11:47 AM, Daniele Romagnoli wrote:
Hi Mike,
No problem on this.
    should?
of GeoServer as a Windows Service doesn't allow to see the GDAL native
investigation, I have found a solution for this (See [1]) and I have
added it to the geoserver's doc. Honestly, I don't know how the
Daniele
[1]:
http://geo-solutions.blogspot.com/2010/02/fix-gdal-extension-not-working-with.html
    Mike Pumphrey
        yet, can I
        Best Regards,
        Daniele
        Software Engineer
        Via Carignoni 51
        55041 Camaiore (LU)
        fax: +39 0584983027
        Download Intel&#174; Parallel Studio Eval
        <mailto:Geoserver-devel@lists.sourceforge.net>
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Hi Mike,
sorry for the late reply.
I usually put the native libs on windows under jdk/bin folder.
However, in a previous email on that topic, Aime suggested he always put the native libs on <current_jdk>/jre/lib/i386/ or <current_jdk>/jre/lib/amd64/ regardless of the OS (Linux/windows). Therefore we can follow that tip. Feedbacks?
In the meantime, I have opened a JIRA:
http://jira.codehaus.org/browse/GEOS-3909
Daniele
Mike Pumphrey
Hi Mike,
No problem on this.
should?
Daniele
Mike Pumphrey
yet, can I
Best Regards,
Daniele
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
mailto:[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@anonymised.comrge.net)
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
