[Geoserver-devel] About GSIP #2
remember GSIP documents? It seems we forgot a little about them?
Anyways, I still have to implement #2.
http://docs.codehaus.org/display/GEOS/GSIP+2+-+Automated+Code+Formatting
Just a couple of questions: do we work with 100 columns lines just like
in geotools? It would be nice to have the same formatting rules since
we are often working on both source code bases.
Besides that, I'm going to add jalopy in a profile, so that you can enable
it as needed instead of having it running all the way during normal builds.
We should make it a convention that it needs to be run once before committing
(and if in that run it refromats other files that lazy developers did not format properly,
that's not your fault, right?)
PS: oh, btw, since now the navigation bar is easily edited, I added a direct
link to the GSIP page.
