I've used geoserver ( rc3) with Oracle 10g... It worked well.. ( Connecting,
getmap with Image/png, Image/jpeg format) but when I have request as:
http://3d:8080/geoserver/wms?request=GetMap&layers=HANOI_ROAD&bbox=1.176091750706E7,2326526.4628375,1.177867477252E7,2347642.9254375&width=597&height=485&srs=EPSG:27354&styles=normal&Format=image/svg+xml
it said:
java.lang.IllegalStateException: getOutputStream() has already been called for
this response
org.apache.coyote.tomcat5.CoyoteResponse.getWriter(CoyoteResponse.java:599)
org.apache.coyote.tomcat5.CoyoteResponseFacade.getWriter(CoyoteResponseFacade.
java:163)
org.vfny.geoserver.servlets.AbstractService.send(AbstractService.java:614)
org.vfny.geoserver.servlets.AbstractService.sendError(AbstractService.java:670)
org.vfny.geoserver.servlets.AbstractService.sendError(AbstractService.java:654)
org.vfny.geoserver.servlets.AbstractService.doService(AbstractService.java:434)
org.vfny.geoserver.servlets.AbstractService.doGet(AbstractService.java:235)
javax.servlet.http.HttpServlet.service(HttpServlet.java:697)
javax.servlet.http.HttpServlet.service(HttpServlet.java:810)
org.vfny.geoserver.servlets.wms.WmsDispatcher.doResponse(WmsDispatcher.java:
137)
org.vfny.geoserver.servlets.wms.WmsDispatcher.doGet(WmsDispatcher.java:106)
and on Tomcat's log file:
87567451 [FINE] org.vfny.geoserver.servlets.AbstractService - mime type is:
image/svg+xml
87567451 [FINE] org.vfny.geoserver.responses.wms.map.svg.EncodeSVG - obtaining
FeatureReader for HANOI_ROAD
87567451 [FINE] org.geotools.filter.SQLEncoderOracle - SQLEncoderOracle:
Geometric Column is: GEOLOC
87567466 [FINE] org.geotools.data.jdbc.JDBCDataStore - calling sql builder
with filter [ GEOLOC bbox POLYGON ((11760917.50706 2326526.4628375,
11760917.50706 2347642.9254375, 11778674.77252 2347642.9254375, 11778674.77252
2326526.4628375, 11760917.50706 2326526.4628375)) ]
87567466 [FINE] org.geotools.filter.SQLEncoderOracle - Using layer SRID:
262148
87567466 [FINE] org.geotools.data.jdbc.JDBCDataStore - sql is SELECT GEOLOC
FROM HANOI_ROAD WHERE NOT SDO_RELATE("GEOLOC",MDSYS.SDO_GEOMETRY(2003,262148,
NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,1),MDSYS.SDO_ORDINATE_ARRAY
(1.176091750706E7,2326526.4628375,1.176091750706E7,2347642.9254375,1.177867477252E7,2347642.9254375,1.177867477252E7,2326526.4628375,1.176091750706E7,2326526.4628375)),
'mask=disjoint querytype=WINDOW') = 'TRUE'
87567466 [FINE] org.geotools.data.jdbc.JDBCDataStore - About to execure query:
SELECT GEOLOC FROM HANOI_ROAD WHERE NOT SDO_RELATE("GEOLOC",MDSYS.SDO_GEOMETRY
(2003,262148,NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,1),MDSYS.SDO_ORDINATE_ARRAY
87567466 [FINE] org.geotools.data.jdbc.ConnectionPool - Getting available
connection.
87567982 [FINE] org.geotools.data.oracle.attributeio.SDOAttributeIO - About to
create Geometry convertor for HANOI_ROAD.GEOLOC
87567982 [FINE] org.vfny.geoserver.responses.wms.map.svg.EncodeSVG - got
FeatureReader, now writing
87567982 [WARNING] org.vfny.geoserver.responses.wms.map.svg.EncodeSVG -
UNCAUGHT exception: No SVG Feature writer defined for class com.vividsolutions.
jts.geom.Geometry
87567982 [FINE] org.geotools.data.jdbc.ConnectionPool$ConnectionListManager -
Connection closed - adding to available connections.
87567982 [FINE] org.vfny.geoserver.responses.wms.GetMapResponse - asking
delegate for aborting the process
87567982 [INFO] org.vfny.geoserver.servlets.AbstractService - Had an undefined
error: UNCAUGHT exception: No SVG Feature writer defined for class com.
vividsolutions.jts.geom.Geometry
87567982 [FINE] org.vfny.geoserver.ServiceException - java.io.IOException:
jts.geom.Geometry
89849545 [FINE] org.vfny.geoserver.requests.readers.KvpRequestReader - clean
request is
request=GetMap&layers=HANOI_ROAD&bbox=579463,2313996,595972,2334980&width=597&height=485&srs=EPSG:
27354&styles=normal&Format=image/svg xml
returning parsed {SRS=EPSG:27354, BBOX=579463,2313996,595972,2334980,
LAYERS=HANOI_ROAD, HEIGHT=485, REQUEST=GetMap, STYLES=normal, WIDTH=597,
FORMAT=image/svg xml}
89849545 [INFO] org.vfny.geoserver.servlets.AbstractService - Looking for
configured service responses' strategy
configured service strategy SPEED
89849545 [FINE] org.vfny.geoserver.servlets.AbstractService - verifying
configured strategy
89849545 [INFO] org.vfny.geoserver.servlets.AbstractService - Using service
strategy class org.vfny.geoserver.servlets.SpeedStrategy
89849545 [FINE] org.vfny.geoserver.servlets.AbstractService - reading request:
89849545 [FINE] org.vfny.geoserver.global.Data - getting type HANOI_ROAD
89849545 [INFO] org.vfny.geoserver.servlets.AbstractService - handling
request: org.vfny.geoserver.requests.wms.GetMapRequest@anonymised.com
89849545 [FINE] org.vfny.geoserver.servlets.AbstractService - strategy is: org.
vfny.geoserver.servlets.SpeedStrategy@anonymised.com
89849545 [FINE] org.vfny.geoserver.responses.wms.map.SVGMapResponse - checking
if can producer image/svg xml, returningtrue
89849545 [FINE] org.vfny.geoserver.responses.wms.map.GetMapDelegate - query
for map is Query:
feature type: HANOI_ROAD
filter: [ GEOLOC bbox POLYGON ((579463 2313996, 579463 2334980, 595972
2334980, 595972 2313996, 579463 2313996)) ]
[properties: GEOLOC]
89849545 [FINE] org.vfny.geoserver.servlets.AbstractService - mime type is:
image/svg+xml
89849545 [FINE] org.vfny.geoserver.responses.wms.map.svg.EncodeSVG - obtaining
89849545 [FINE] org.geotools.filter.SQLEncoderOracle - SQLEncoderOracle:
89849545 [FINE] org.geotools.data.jdbc.JDBCDataStore - calling sql builder
with filter [ GEOLOC bbox POLYGON ((579463 2313996, 579463 2334980, 595972
89849545 [FINE] org.geotools.filter.SQLEncoderOracle - Using layer SRID:
262148
89849545 [FINE] org.geotools.data.jdbc.JDBCDataStore - sql is SELECT GEOLOC
(579463.0,2313996.0,579463.0,2334980.0,595972.0,2334980.0,595972.0,2313996.0,579463.0,2313996.0)),
89849545 [FINE] org.geotools.data.jdbc.JDBCDataStore - About to execure query:
89849545 [FINE] org.geotools.data.jdbc.ConnectionPool - Getting available
connection.
89873701 [FINE] org.geotools.data.oracle.attributeio.SDOAttributeIO - About to
89873701 [FINE] org.vfny.geoserver.responses.wms.map.svg.EncodeSVG - got
89873701 [WARNING] org.vfny.geoserver.responses.wms.map.svg.EncodeSVG -
jts.geom.Geometry
89873701 [FINE] org.geotools.data.jdbc.ConnectionPool$ConnectionListManager -
89873701 [FINE] org.vfny.geoserver.responses.wms.GetMapResponse - asking
89873701 [INFO] org.vfny.geoserver.servlets.AbstractService - Had an undefined
89873701 [FINE] org.vfny.geoserver.ServiceException - java.io.IOException:
jts.geom.Geometry
How can i solve the problem...
P/S with Postgis, shape file it works well all out put format ( png, jpg,
bitmap and svg)
thanks
