I’m newbie to GEOSERVER. I want to know about REST Extension of GEOSERVER, how to use it, how to call it. I try to call REST API through curl in Window XP but it always response in html and also I only can call GET method, not PUT, DELETE… I installed GEOSERVER 1.7.3 and restconfig 1.7.3 extension. Please help me.
I assume you found the docs? I think this kind of question should be
sent to the user list - this devel list is mostly for people hacking
on geoserver.
Jody
On Sat, Mar 21, 2009 at 3:39 AM, Nguyen Tuan Son <tuanson@anonymised.com> wrote:
Please help me.
Tuan Son
Apps built with the Adobe(R) Flex(R) framework and Flex Builder(TM) are
powering Web 2.0 with engaging, cross-platform capabilities. Quickly and
easily build your RIAs with Flex Builder, the Eclipse(TM)based development
software that enables intelligent coding and step-through debugging.
Download the free 60 day trial. http://p.sf.net/sfu/www-adobe-com
Geoserver-devel mailing list
Geoserver-devel@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-devel
If you tell curl to display headers from the result, ("curl -D -" is the
way I usually do that) you should see you're getting a permissions
error. Non-GET operations against the REST API are disabled for
unauthenticated users, so you should include user info in your request;
you can do this by including user:pass@ in the URL
(http://admin:passwd@anonymised.com:8080/geoserver/…)
on geoserver.
Jody
> Hi all,
> Please help me.
> Thanks,
> Tuan Son
If you could keep the discussion on the public mailing list that would be appreciated.
Afaik netcdf will now work properly with the current REST extensions. Others will have to clarify but the reason is that netCDF does not operate like a regular coverage stores. Support for it historically has more or less been a workaround afaik.
-Justin
Nguyen Tuan Son wrote:
Thanks so much,
I can call the REST API now. But now I want to know how can I use NetCDF data file with GEOSERVER. Can
you help me or do you have any suggestion for that ?
Best Regards,
Tuan Son
Justin Deoliveira
OpenGeo - http://opengeo.org
