[Geoserver-devel] About scripting in geoserver
Hi.
I’m using geoserver 2.8.1, builded from sources, and on runtime format.
I’m trying to run python code to do customs, in geoserver.
I did install the wps extension, create the data_dir/scripts/wps directory, and put my sample.py on it.
I’m not getting type py:sample on the demo/wps request builder.
I did detect (in the builded from sources version), a message “2016-06-01 18:14:22,784 DEBUG [script.wps] - Skipping sample.py, no hook found”
I did try, too, to install the python extension (documented on http://docs.geoserver.org/2.6.x/en/user/community/python/installation.html).
This method is no longer available in versions 2.8.x or higher? It was replaced by something else?
Surely I’m wrong in the process. someone can give me a hint?
TIA
jorge infante
rosario - santa fe - argentina
Hi Jorge,
The docs you are looking at are for the old “python” extension that pre-dates the “script” extension. You should follow the documentation located here:
http://docs.geoserver.org/stable/en/user/community/scripting/index.html
In particular if you are looking to hook into wps you can find some details and samples here:
http://docs.geoserver.org/stable/en/user/community/scripting/hooks.html#web-processing-service
Hope that helps.
-Justin
On Thu, Jun 2, 2016 at 5:36 AM Jorge Infante <joluinfante@anonymised.com> wrote:
Hi.
TIA
jorge infante
What NetFlow Analyzer can do for you? Monitors network bandwidth and traffic
patterns at an interface-level. Reveals which users, apps, and protocols are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity
planning reports. https://ad.doubleclick.net/ddm/clk/305295220;132659582;e_______________________________________________
Geoserver-devel mailing list
Ok, Justin.
I’m trying to use wps to implement my service.
I did try a basic “hello world” sample. My sample try to return a string with “hello world”:
#more scripts/wps/sample.py
from geoserver.wps import process
from StringIO import StringIO
@process(
title=‘Sample’,
description=‘Sample’,
inputs={},
outputs={‘result’: (StringIO, ‘The constant hello world’)}
def run():
buff = StringIO(“hello world”)
return buff;
When I try to execute the process with:
wget “http://localhost:8080/geoserver/wps?service=WPS&version=1.0.0&request=Execute&identifier=py:sample” -O -
I don’t have errors, but, I can’t to see the “hello world” text.
I’m thinking the problem is the output definition. What is the list of datatypes on this?
2016-06-02 10:33 GMT-03:00 Justin Deoliveira <jdeolive@anonymised.com>:
Hi Jorge,
Hope that helps.
-Justin
On Thu, Jun 2, 2016 at 5:36 AM Jorge Infante <joluinfante@anonymised.com3…> wrote:
Hi.
TIA
jorge infante
Ok. I did resolve it:
#from geoscript.geom import Geometry
@process(
title=‘Sample’,
inputs={‘arg1’: (int, ‘first argument’),
‘arg2’: (int, ‘second argument’)},
outputs={‘result’: (str, ‘The buffered geometry’)}
def run(arg1, arg2):
#return “hello world”;
return str(arg1+arg2);
I’ll continue working on it. Thanks for the help.
2016-06-29 8:06 GMT-03:00 Jorge Infante <joluinfante@anonymised.com>:
Ok, Justin.
@process(
title=‘Sample’,
inputs={},
def run():
return buff;
Hi Jorge,
Hope that helps.
-Justin
Hi.
TIA
jorge infante
Hi!
I’m trying to execute my wps script, using wget (to test), but, I need “login to geoserver” (like “Authenticate (will run the request as anonymous otherwise” checkbox on “WPS request builder”).
What is the method to do it?
I’m using the sentence:
wget “http://localhost:8080/geoserver/wps?service=WPS&version=1.0.0&request=Execute&identifier=py:sample1&datainputs=param1=xx;param2=yy” -O -
Thanks
jorge infante
2016-06-29 8:21 GMT-03:00 Jorge Infante <joluinfante@anonymised.com>:
@process(
title=‘Sample’,
Ok, Justin.
@process(
title=‘Sample’,
inputs={},
def run():
return buff;
Hi Jorge,
Hope that helps.
-Justin
Hi.
TIA
jorge infante
You need to provide the --user & --password options to WGET or if you use curl the option is -u username:passwd
Ian
On 5 July 2016 at 12:16, Jorge Infante <joluinfante@anonymised.com> wrote:
Hi!
Thanks
jorge infante
Attend Shape: An AT&T Tech Expo July 15-16. Meet us at AT&T Park in San
Francisco, CA to explore cutting-edge tech and listen to tech luminaries
present their vision of the future. This family event has something for
everyone, including kids. Get more information and register today.
http://sdm.link/attshape
@process(
title=‘Sample’,
Ok, Justin.
@process(
title=‘Sample’,
inputs={},
def run():
return buff;
Hi Jorge,
Hope that helps.
-Justin
Hi.
TIA
jorge infante
Ian Turton
Is not working.
I did try with --user and --http-user, and, I’m receiving:
–2016-07-05 17:38:12-- http://localhost:8080/geoserver/wps?service=WPS&version=1.0.0&request=Execute&identifier=py:sample1&datainputs=param1=xx;param2=xx
Resolving localhost (localhost)… ::1, 127.0.0.1
Connecting to localhost (localhost)|::1|:8080… connected.
HTTP request sent, awaiting response… 200 OK
Length: unspecified [application/xml]
Saving to: ‘STDOUT’
py:sample1</ows:Identifier>ows:TitleSample</ows:Title>ows:AbstractSample</ows:Abstract><
/wps:Process><wps:Status creationTime=“2016-07-05T20:38:12.595Z”>wps:ProcessFailed<ows:Excepti
onReport version=“1.1.0”><ows:Exception exceptionCode=“NoApplicableCode”>ows:ExceptionTextProc
ess failed during execution
File "pyclasspath/geoserver/wps.py", line 19, in wrapped
File "/instalar/geoserver/geoserver-2.8.1/bin/…/data_dir/scripts/wps/sample1.py&
quot;, line 24, in run
manzanas=Layer('muni:manzanas') ← I can’t to access because the access was by anonymous
File "pyclasspath/geoserver/catalog/layer.py", line 54, in init
Exception: Unable to find store for layer muni:manzanas
</ows:ExceptionText></ows:Exception></ows:ExceptionReport></wps:ProcessFailed></wps:Status></wps
  • [ <=> ] 1.22K --.-KB/s in 0s
2016-07-05 17:38:12 (78.7 MB/s) - written to stdout [1251]
The wps/python script:
from geoserver.catalog import Catalog, Workspace, Layer
@process(
title=‘Sample’,
inputs={‘login’: (str, ‘login’),
‘password’: (str, ‘password’)},
outputs={‘result’: (str, ‘login status’)})
def run(login, password):
debug_file=“/tmp/geoserver.log”
f=open(debug_file, “a”)
f.write(“login=”+login+" password=“+password+”\n")
cat=Catalog()
f.write(str(cat.keys()))
f.write(“\n”)
2016-07-05 9:05 GMT-03:00 Ian Turton <ijturton@anonymised.com>:
Ian
Hi!
Thanks
jorge infante
Ian Turton
@process(
title=‘Sample’,
Ok, Justin.
@process(
title=‘Sample’,
inputs={},
def run():
return buff;
Hi Jorge,
Hope that helps.
-Justin
Hi.
TIA
jorge infante
I’m seeing my problem is:
  • The caller is putting user and password.
  • The wps python script is running in anonymous mode.
  • What is the method to init the session on geoserver (from wps python script) with the user and password received?
TIA
jorge infante
2016-07-05 17:40 GMT-03:00 Jorge Infante <joluinfante@anonymised.com>:
Is not working.
Saving to: ‘STDOUT’
  • [<=> ] 0 --.-KB/s <
    ?xml version=“1.0” encoding=“UTF-8”?><wps:ExecuteResponse xmlns:xs=“http://www.w3.org/2001/XMLSc
    hema” xmlns:wps=“http://www.opengis.net/wps/1.0.0” xmlns:ows=“http://www.opengis.net/ows/1.1” xm
    lns:xlink=“http://www.w3.org/1999/xlink” xml:lang=“en” service=“WPS” serviceInstance=“http://loc
    alhost:8080/geoserver/ows?” version=“1.0.0”><wps:Process wps:processVersion=“1.0.0”><ows:Identif
    ier>py:sample1</ows:Identifier>ows:TitleSample</ows:Title>ows:AbstractSample</ows:Abstract><
@process(
title=‘Sample’,
cat=Catalog()
f.write(“\n”)
topp=Workspace(‘muni’)
f.write(topp.name+“\n”)
f.write(topp.uri+“\n”)
f.write(str(topp.keys()))
f.write(“\n”)
manzanas=Layer(‘muni:manzanas’)
f.write(manzanas.name+“\n”)
f.write(str(manzanas.data.schema)+“\n”)
f.write(str(manzanas.data.count())+“\n”)
f.close()
return “OK”;
Ian
On 5 July 2016 at 12:16, Jorge Infante <joluinfante@anonymised.com…403…> wrote:
Hi!
Thanks
jorge infante
Ian Turton
@process(
title=‘Sample’,
Ok, Justin.
@process(
title=‘Sample’,
inputs={},
def run():
return buff;
Hi Jorge,
Hope that helps.
-Justin
Hi.
TIA
jorge infante
