I believe you should find it in the REST representation, but it’s a bit finicky because
it’s a property that was not there in the original model, so it’s a Boolean (object reference),
null by default, and assumed to be “true” when missing (for backwards compatbilty, allows
for transparent upgrades).
Long story short, you won’t find it unless you edited it manually.
If I set it to false in the UI, then I can see:
countries
VECTOR
polygon
<atom:link xmlns:atom=“http://www.w3.org/2005/Atom” rel=“alternate” href=“http://cloudsdi.geo-solutions.it/geoserver/rest/styles/polygon.xml” type=“application/xml”/>
test:countries
<atom:link xmlns:atom=“http://www.w3.org/2005/Atom” rel=“alternate” href=“http://cloudsdi.geo-solutions.it/geoserver/rest/workspaces/test/datastores/world/featuretypes/countries.xml” type=“application/xml”/>
false
0
0
and then go back and edit again to re-enable it:
countries
VECTOR
polygon
test:countries
true
0
0
But normally it’s just not there. Hope this helps
On Wed, Mar 14, 2018 at 1:16 AM, Raif S. Naffah <raif@anonymised.com> wrote:
hi,
a week ago i posted this to the users list but got no response. would
appreciate it if a GeoServer developer can find the time to give some
feedback:
quote
unless i missed the obvious, using GeoServer 2.8.5 the ‘Queryable’ flag
of a Layer appears in the [Edit Layer] Admin GUI page (under the [WMS
Settings] sub-heading w/in [Publishing] panel) but does not seem to be
included in the Response to either a Layer or a FeatureType GET
Requests.
is it possible to get hold of this information w/ REST calls?
if not then would it be advisable to write a WPS function to return
this information? the code of the ImportProcess suggests that it is
possible --by calling org.geoserver.catalog.LayerInfo#isQueryable().
unquote
TIA + cheers;
rsn
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Andrea Aime
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
