[Geoserver-devel] Access to geoserver/docker wiki
as discussed in the meeting on Tuesday, i'd like to add a table-based comparison of the two docker approaches we currently have.
But it seems that i don't have sufficient rights to create an initial wiki page. https://github.com/geoserver/docker/wiki is forwarding to https://github.com/geoserver/docker
I also tried "git clone git@anonymised.com:geoserver/docker.wiki.git" but i get "fatal: remote error: access denied or repository not exported: /c/nw/c0/87/76/230472445/209116917.wiki.git"
I think this is related to the fact that there is no initial wiki yet.
So maybe someone with sufficient rights can create an empty wiki page and or give me (buehner) rights to edit there?
Thank you,
Nils
Hi Nils,
page created and I’ve added you to the docker team, hopefully that gives you edit rights on the wiki
Regards, Andrea Aime
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Hi Andrea,
thanks for the quick help, but i am still missing sufficient rights as i don’t get the “edit” or “new page” buttons in the browser.
I was able to git clone the wiki, but it is not possible to push changes:
11:08 $ git push origin master
ERROR: Permission to geoserver/docker.wiki.git denied to buehner.
fatal: Could not read from remote repository.
Please make sure you have the correct access rights
and the repository exists.
I will prepare the comparison now and once i have sufficient rights, i will push them.
Nils
On 2/5/21 11:04 AM, Andrea Aime wrote:
Hi Nils,
On Fri, Feb 5, 2021 at 10:56 AM Nils Bühner <buehner@anonymised.com> wrote:
as discussed in the meeting on Tuesday, i’d like to add a table-based
But it seems that i don’t have sufficient rights to create an initial
I also tried “git clone git@anonymised.com:geoserver/docker.wiki.git” but i
get “fatal: remote error: access denied or repository not exported:
/c/nw/c0/87/76/230472445/209116917.wiki.git”
Thank you,
Nils
Geoserver-devel mailing list
Geoserver-devel@anonymised.coms.sourceforge.net
i am still missing the necessary rights to edit the wiki on https://github.com/geoserver/docker/wiki
It would be really great if someone could grant me these rights as i have prepared a first comparison of the two docker approaches and it would be nice if i could push them there for discussion.
Best regards,
Nils
On 2/5/21 11:18 AM, Nils Bühner wrote:
Hi Andrea,
Nils
Hi Nils,
Thank you,
Nils
[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@anonymised.comsourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
I have been looking a bit more, it seems Jody is the only admin of the repository.
I cannot change the access settings of the “team docker”, which are indeed only allowed to read
the repository.
So I guess we’ll have to wait for Jody to notice this mail thread. I’ll try to remind him tonight at the PSC meeting.
Hi Nils,
While we wait for the grants to write to the wiki can you please send over a draft so I can take a look at it?
Thanks a lot,
Alessandro
Alessandro Parma
Alessandro Parma
DevOps Engineer
Nils you are already a member of the docker team so I am not sure what else is needed? I will change the permissions from “write” to “maintain” to see if it makes a difference.
The wiki is setup with “Restrict editing to users in teams with push access only” the same as GeoServer wiki.
Jody Garnett
Hi Jody,
I also don’t seem to have write access to the wiki:
Alessandro Parma
Alessandro Parma
DevOps Engineer
Hi Alessandro,
Jody gave me some more rights in the meantime. I tried adding you to the team.
Can you access it, and make changes, now?
(attachments)
Yup, Looks good now
Thanks @Jody Garnett @Andrea Aime
(attachments)
Alessandro Parma
Alessandro Parma
DevOps Engineer
Awesome, you have the same permissions as Nils, so he should be able to edit too.
(attachments)
